using PORT A of 16f870
Discussion in 'Microcontrollers, Programming and IoT' started by gurjant.sandhu33, Mar 16, 2014.
  1. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    how to use the adc port A of pic 16f870 as a normal port. like the port B and port C.
    is there any special code for it or just trisa=0xff is enough.
  2. BobK
    7,682
    1,688
    Did you try reading the datasheet?
  3. kpatz
    kpatz
    330
    88
    Feb 24, 2014
    Look in the datasheet for how to initialize the ADCON0 and ADCON1 registers. From there you should be able to figure it out.
  4. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    The use of RA0~3, RA5 and RE0~2 is controlled by the PCFG3~0 bits in ADCON1 according to a big table. The device only supports certain combinations, and those bit settings also determine where the ADC gets its positive and negative reference voltages from.
    Look through that table for a suitable combination of ADC and digital I/O functions and set those bits accordingly.
  5. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    thank for your suggestions.
    i came to know that ADCON1 value must be 0x05 and my work will be complete.
