Using phone as PC microphone
  • Thread starter .:: Evanescence ::.
  • Start date
E
.:: Evanescence ::.
Hello people.
With voice chat programs on PC like MSN Messenger and Skype, I thought
it would be cool to use a real phone as a PC microphone.
Q: Does someone here knows how to adapt a real phone to be used as a PC
microphone?
M
Michael A. Covington
.:: Evanescence ::. said:
Hello people.
microphone?
One way that should work:
Connect the telephone in series with a 1000-ohm resistor and a 9-volt
battery.
Take the signal across the 1000-ohm resistor and feed to Line In (not Mic
In) on the soundcard.
Current is drawn from the battery only when the phone is off the hook.
You could arrange a more subtle solution that involves stealing 5 volts from
the PC, and isolating the phone circuit with a capacitor.
P
Pooh Bear
Hello people.
microphone?
Those companies selling VOIP telephony can offer USB phone handsets IIRC.
Graham
E
.:: Evanescence ::.
Pooh Bear wrote on sci.electronics.design:
IIRC.
I will check, but I am interest in making it on my own.
What do I need to use a phone as a microphone for PC? Any amplifier is
need?
M
need?
No. If you put the telephone in series with a 9 volt battery and a 1000-ohm
resistor, you will have line-level audio across the resistor.
E
.:: Evanescence ::.
Michael A. Covington wrote on sci.electronics.design:
battery.
Mic In) on the soundcard.
I am try this. Thanks!
[]s
e.
E
.:: Evanescence ::.
1000-ohm resistor, you will have line-level audio across the resistor.
Hm. Thanks.
