using natural gas to generate electricity
Discussion in 'Hobby Electronics' started by Mr Mac, Apr 2, 2011.
  1. Mr Mac
    Mr Mac Guest
    Here is an idea, get a regular (say) Holden V6 engine, convert it to natural
    gas, and connect it to a 100KW electricity generator. You should be able to
    find something from an army disposal sale. Total cost, say $2000 for the
    engine and $3000 for the generator for a total of $5000 plus a bit of elbow
    grease.
    Make sure the genny can supply a peak of 100KW, but typically put out say
    20KW of constant reliable power.
    Then get all your neighbours (preferably the whole street) to sign up to
    your "electricity company" and make money!
    Let's do the math to see if it is viable:
    According to Origin Energy, gas is 1.1021 cents per Megajoule (in Melbourne
    metropolitan area, Australia)
    So One Watt (W) is 1 Joule per second, 1W=1J/s. So a kW=1000W=1000J/s. There
    are 60*60 seconds in an hour, so a Kilowatt hour is
    3600*1000 J=3.6*10^6 J. One mega-joule is 1 million Joules, 1MJ=10^6 J, so 1
    kWh=3.6 MJ.
    So with gas, 3.6MJ, or 1KWh will cost 3.3 cents.
    But 1KWh of electricity from that greedy electricity company costs around
    $0.18 to $0.20 so what is your break even point?
    Now lets say you sell electricity to your neighbours for 18.3 cents per KWh,
    so you are competitive.... your running profit per KWh is 18.3 - 3.3 = 15
    cents.
    How long will it take to get that $5000 investment back?
    Well you will need to sell 5000/0.15 = 33333KWh to break even. Now how much
    does the average house use????? That is a big question. My use is around
    10KWh per day but the figure seems to vary widely from house to house.
    http://www.abcdiamond.com/australia/average-household-electricity-consumption/
    Now I will use an average of 10KWh per day per house. Say you have 10 houses
    connected to your little scheme, just to keep the numbers round. The 10
    houses shouldn't overload the 20KW generator, with 100KW peak capacity, so I
    think that is a realistic number anyway.
    So at 100KWh generated per day, it will take 333.3 days, or just under a
    year, to get your money back.
    Will the engine run for a year, non stop? I would say yes. Plenty of taxis
    clock up millions of km.... and apparently running an engine on natural gas
    is good for it.
    From Wikipedia:
    Due to the absence of any lead or benzene content in CNG, the lead fouling
    of spark plugs is eliminated. CNG-powered vehicles have lower maintenance
    costs when compared with other fuel-powered vehicles. CNG fuel systems are
    sealed, which prevents any spill or evaporation losses. Another practical
    advantage observed is the increased life of lubricating oils, as CNG does
    not contaminate and dilute the crankcase oil. CNG mixes easily and evenly in
    air being a gaseous fuel. CNG is less likely to auto-ignite on hot surfaces,
    since it has a high auto-ignition temperature (540 °C) and a narrow range
    (5%-15%) of flammability.[6]
    CNG emits significantly less pollutants such as carbon dioxide (CO2),
    hydrocarbons (UHC), carbon monoxide (CO), nitrogen oxides (NOx), sulfur
    oxides (SOx) and particulate matter (PM), compared to petrol. For example,
    an engine running on petrol for 100 km emits 22,000 grams of CO2, while
    covering the same distance on CNG emits only 16,275 grams of CO2. [CNG is
    essentially methane, i.e. CH4 with a calorific value of 900 Kj/mol. This
    burns with Oxygen to produce 1 mol of CO2 and 2 mol of H2O. By comparison,
    petrol can be regarded as essentially Benzene or similar, C6H6 with a
    calorific value of about 3,300 Kj/mol and this burns to produce 6 mol of CO2
    and 3 mol of H2O. From this it can be seen that per mol of CO2 produced, CNG
    releases over 1.6 times as much energy as that released from petrol (or for
    the same amount of energy, CNG produces nearly 40% less CO2).] The
    corresponding figures are 78 and 25.8 grams respectively, for nitrogen
    oxides. Carbon monoxide emissions are reduced even further. Due to lower
    carbon dioxide and nitrogen oxides emissions, switching to CNG can help
    mitigate greenhouse gas emissions.[6] The ability of CNG to reduce
    greenhouse gas emissions over the entire fuel lifecycle will depend on the
    source of the natural gas and the fuel it is replacing. The lifecycle
    greenhouse gas emissions for CNG compressed from California's pipeline
    natural gas is given a value of 67.70 grams of CO2-equivalent per megajoule
    (gCO2e/MJ) by the California Air Resources Board (ARB), approximately 28%
    lower than the average gasoline fuel in that market (95.86 gCO2e/MJ). CNG
    produced from landfill biogas was found by ARB to have the lowest greenhouse
    gas emissions of any fuel analyzed, with a value of 11.26 gCO2e/MJ (over 88%
    lower than conventional gasoline) in the low-carbon fuel standard that went
    into effect on January 12, 2010.[7]
    BUT, Back to the story,.... how long will that Holden engine really last?
    Hard to say, without actually giving it a go, but let's do some more
    educated guesses.
    A regular Holden Commodore is pretty shagged with 300 000 km on the
    odometer. So lets use that as a base. How many hours of operation would that
    be?
    Now if we use the engine as a generator, it's fair to say that we are
    treating the engine nicely. There are no cold starts, the acceleration is
    smooth, there is no stop-start traffic like you have on a real road, so you
    could maybe assume that if it was compared to a car driven carefully and
    nicely on the road, and you treated it right, it could make the 1 million km
    mark without having to be re-built. OK OK, I know what you're thinking,
    overly optimistic, let's make it more like 500 000 km. How many ***hours***
    of operation is that. Well assuming 60 km per hour average, that's 8333
    hours of operation.
    Now we broke even after 333 days of operation, which is 7992 hours, so
    8333-7992 = 341 glorious hours of selling electricity at 100% profit.
    341/24 = 14.2 days, and with 100KWh sold per day, thats 14.2x100x0.183=
    $259.86 dollars of cold hard profit, before the engine gets changed over.
    OK probably not worth the trouble. Never mind, carry on, nothing to see
    here.
  2. Sylvia Else
    Sylvia Else Guest
    Whose wiring were you proposing to use to do this?
    No it won't. You're running a heat engine. You cannot extract all the
    energy from the gas. With your converted petrol engine, you cannot even
    extract most of it. See
    http://en.wikipedia.org/wiki/Carnot_cycle
  3. Mr Mac
    Mr Mac Guest
    I assumed that the power generation from gas to electricity was 100%
    efficient. Obviously that's not the case, but it is conceivable that the
    waste heat generated by the engine could be used to heat up a large water
    container, which could then be piped to the customers, and still be put to
    good use.
    Also, while the engine would have to be replaced yearly, I'd say the
    generator would last a lot longer. No brushes, so just bearings every few
    years.
  4. Sylvia Else
    Sylvia Else Guest
    Then you need a means of capturing the heat, pipework to deliver the hot
    water, and meters to measure it.
    You also need a way of billing customers, obtaining their payments,
    dealing with people who don't pay, and so on.
    It all adds to the cost.
    Did you check the capacity of the gas main? Is it capable of delivering
    the extra gas? If not, then it will have to be enlarged, and someone
    will have to pay for that.
    Kreed mentions noise. Yes, there will need to be sound insulation. More
    cost.
    The harsh reality is that owning and operating a generator is not a
    licence to print money.
    Sylvia.
  5. terryc
    terryc Guest
    Now apply 5% efficency of conversion and see what you get.
    Hint, go read the wikipedia article on the solar panel, especially the
    bits on price parity.
  6. Mr Mac
    Mr Mac Guest
    5% sounds a bit low.
    The Holden Omega V6 engine uses 10.9 litres per 100km, and is rated at 190KW
    at 6700RPM. I'll assume that it needs 20KW to cruise at 100km/h. (if you
    have some real data, I would love to see it)
    What is the real efficiency:
    Well petrol has an energy of 32MJ per litre which is 8.89KWh per litre.
    Multiplied by 10.9 (litres in one hour of the engine outputting 20KW) gives
    96.89KWh
    So we burn close to 100KWh of petrol to get 20KWh of real work..... or
    around 20% efficient.
    So yes, not very good figures. But heat is the biggest by-product. If we can
    use the heat to warm up our houses, and swimming pools, and hot water
    systems, we can internalise most of the losses.
    Say you have a group of 10 to 20 apartments in a cold climate, where the
    heat is not wasted, but put to good use. It's conceivable that you will get
    close to the system working out.
  7. Sylvia Else
    Sylvia Else Guest
    That's certainly the correct result, but I think the technical/economics
    arguments still need to be expressed, because otherwise people, even
    those who would be willing to examine and understand the arguments, can
    be left with the impression that the whole thing is a scam by which
    people are sold overpriced electricity.
    Mind you, I was watching Energy Australia do some substation work near
    my home the other day. They'd closed one side of the road, and had two
    people controlling traffic through the one remaining lane. I have to
    wonder whether that's really the cheapest way of doing that - portable
    automatic traffic lights are available.
    Sylvia.
  8. Phil Allison
    Phil Allison Guest
    "Mr Mac"
    ** Completely nuts.
    If you have gas available - then so do all your neighbours.
    They will already be using it DIRECTLY it for hot water, cooking and home
    heating - which are the 3 major consumers of energy in a home. Only their
    fridges, CFL lights and small appliances use electricity - plus air con if
    they have any.
    Gas homes generally have rather small electric bills.
    BTW:
    Gas appliances are rather inefficient as much waste heat energy goes up
    flues etc.
    ..... Phil
  9. terryc
    terryc Guest
    Sure it wasn't NY USA you are thinking of? same steam heating and
    exhaust vents releasing steam.
  10. Swanny
    Swanny Guest
    That's a bit like buying a PC and calling yourself an ISP.
  11. Swanny
    Swanny Guest
    And whre is the generator infrastructure located? Certainly can't be on
    someone's residential block. The location would need special zoning.
  12. I had a similar idea on a much smaller scale ie convert one of those
    small el cheapo generators from Bunnings to run on natural gas and use
    it for backup during power outages.
    Suspect this may not be possible as they are 2 strokes so presumably
    lubrication would be a problem?
    Anyway, as I would have to pay someone to do the conversion, I imagine
    this would be a really bad idea financially.
    Dave Goldfinch
  13. Mr Mac
    Mr Mac Guest
    That's a very interesting building. I had no idea what cogeneration was.
    This is more or less where my "invention" was heading in my head.
    The electricity factories burn coal, and are probably around 50% efficient
    at best (I bet its more like 40). The waste heat is dumped into lakes and
    ponds. Google Hazelwood pondage in Melbourne, I waterski there during
    winter! The lake is heated by the adjacent power factory, and is too hot to
    use in summer.
    So when we heat our houses with electricity, after conversion from coal,
    then transmission losses, we are probably only using 20% of the original
    energy found in the original coal. In many ways we are much less efficient
    at heating our houses than the poorest houses in China, where they use coal
    directly in the home. That's a pretty sad fact.
    The issue of noise and pollution is nothing. My math shows that a single V6
    engine is enough for a group of 10 to 20 houses. A suitably built and
    suitably placed generator will be less noisy than passing cars on the roads
    outside. Cars are very quiet these days. All I hear from the road outside is
    tyre and wind noise, I only hear engine noise from older cars.
  14. atec77
    atec77 Guest
    A small turbine genny set is viable and atm actually affordable
  15. Mr Mac
    Mr Mac Guest
    Where did you find a turbine genny that was affordable?
  16. atec77
    atec77 Guest
    China of course , you don't get those emails I think
  17. terryc
    terryc Guest
    Then you are just idling the engine. Ideally you set the engine revs at
    the maximum efficency, then gear the generator to run at the required
    cycles, also chosing the right size (power) generator. We are not
    talking about sing the car alternator here.
  18. Grant
    Grant Guest
    Has anyone considering this done the math on cost of gas through the
    25% efficiency of the motor and compared that to electricity charges?
    If you could a) suck enough gas to run a motor, b) easily generate own
    power, c) make an ROI, don't you think Honda and other generator makers
    would be tapping this market to sell generator sets running off gas?
    Do you recall any motors running off propane bottles? Where they're
    used? Why?
    Grant.
  19. terryc
    terryc Guest
    Large scale, plenty of underground coal mines look at it and quite a few
    have high enough gas concentrations in their exhaust vents to do so.
    A few rubbish pits have now also been tapped for gas powered generation.
    At one stage, it home-bloke wanted to used LPG, you purchased a petrol
    powered generator and had it converted to lpg. It cost about $400
    Now, you can buy a range of lpg powered generators. Do a web search.
    Why? Petrol is explosive, hard to store, convenience, etc.
    Note, i'm not the person promoting the enginer conversion.
  20. Jasen Betts
    Jasen Betts Guest
    a: standby generators, other standby uses
    b: some forklifts
    a: the shelf-life of petrol is a few months unless kept in a sealed container.
    b: not sure, perhaps it's cheaper?
