Using mobile phone as an internet radio
Discussion in 'Electronic Basics' started by jim stone, Oct 2, 2012.
  1. jim stone
    jim stone Guest
    Not being able to find a small internet radio to buy we liked, we got mobile
    phone with which we link with wi-fi to a modem router, and use it as an
    internet radio.
    Keeping the phoned plugged into its charger all the time, we are using it to
    play *all-day* background classical music through an amplifier and speakers.
    Since the phone has no 'moving parts' unlike a computer, we are wondering if
    this continuous playing all day of the phone is going to shorten its working
    life ?
  2. Tom Biasi
    Tom Biasi Guest
    Using anything shortens it's working life.
  3. Not so. There aren't any obvious failure mechanisms in solid-state devices
    (other than dopant migration in high-power output transistors).
    It's also true that most mechanical devices "like" moderate use. Letting
    anything mechanical "sit" most of the time will probably cause it fail
    sooner than if receives regular use.
    It's now possible to build computers without moving parts (other than the
    optical drives). My new computer has a solid-state "hard disk", and you
    wouldn't believe how fast it boots up, or how fast programs start to run.
  4. Tom Biasi
    Tom Biasi Guest
    There are many factors that cause something to fail. I you don't use it,
    it has no working life. I don't wish to play semantics but if you use it
    you are using up it's working life.
  5. There are many factors that cause something to fail. I you
    Not so. With mechanical devices, regular moderate use provides a longer
    useful lifetime than using the device only rarely.
  6. These, if flash memory, do have a definite wear out mechanism, although
    they do try to avoid writing to the same spot, even if the software
    does, to mitigate this.
  7. Tom Biasi
    Tom Biasi Guest
    I don't agree but will say no more.
    Regards,
    Tom
  8. Guest
    The battery may not like being plugged in forever.
  9. Guest
    How much did you pay for the phone? Would it bother you greatly if it is stolen or if the battery fails to hold a charge, did you get it fairly cheap, did you buy a new mobile phone for regular use and this is an old phone from a previous cellular plan, etc.?
    I used to use an old cell phone (well, it was "old" in the sense that I changed cell phone carriers) to play music from the internal microSD card for my plants in my office (a Mythbusters episode showed that plants like music), until the repetition of the songs drove *me* crazy. =)
  10. Graham.
    Graham. Guest
    Not sure if my News server supports x-posts to the entire Usenet, but
    I digress.
    An incandescent light bulb is a good example, If it lasts 1000 hours
    when run continuously, its life will be considerably shorter if run
    (say) 4 hours a day and the time it is on added up.
    Equipment with lots of thermionic devices like very early computers
    were, as far as practical, never switched off because of the
    likelihood of failure.
  11. Phil Allison
    Phil Allison Guest
    "Graham."
    ** Where ever did you get that nonsense from ??
    Some web forum ?
  12. JoRob64
    JoRob64 Guest
    I believe turning the bulbs on and off can induce thermal shock which causes
    premature failure.
    http://en.wikipedia.org/wiki/Thermal_shock
    See also: http://en.wikipedia.org/wiki/Thermionic_valves
    "The common wisdom was that valves—which, like light bulbs, contained a hot
    glowing filament—could never be used satisfactorily in large numbers, for
    they were unreliable, and in a large installation too many would fail in too
    short a time".[13] Tommy Flowers, who later designed Colossus, "discovered
    that, so long as valves were switched on and left on, they could operate
    reliably for very long periods, especially if their 'heaters' were run on a
    reduced current".
  13. Correct. SSDs are an exception. They contain "leveling" software that makes
    sure the disk is written to evenly. The Crucial disk I use is spec'd at
    about 40TB of total writes.
  14. Phil Allison
    Phil Allison Guest
    "JoRob64"
    ** Bollocks it does.
    There are many applications where incandescent lamps are turned on and off
    constantly and their life span is the same.
    The OP's hypothetical example ( don't ya just LOVE them) is typical of
    domestic lamp use.
    Fuckwit.
    ..... Phil
  15. Buffalo
    Buffalo Guest
    No Phil, that is not correct. If he only listens to Rap , its lifespan will
    be shortend greatly.
    Buffalo
  16. hr(bob)
    hr(bob) Guest
    He is right, the stresses involved in the turn-on of the bulb each
    time is equal to several hours of continuous running. If you cycle a
    bulb on and off every few seconds, the total on time before the bulb
    fails will be only a few hundered hours for a 1000 hour rated bulb,
  17. MikeS
    MikeS Guest
    Seems to go against the whole ethos of exercising. Never get out of bed and
    live forever ...
  18. Paul D Smith
    Paul D Smith Guest
    You'll have dropped it well before it wears out :). BTW, a cheap PC
    speaker set might be handy if you want a little more volume. And you can
    probably find a decent streaming client if you have your music sitting on a
    PC somewhere.
    Paul DS.
  19. Brian Gaff
    Brian Gaff Guest
    Just like not using it does in fact.
    Brian
  20. It would be a strange way to rate the life of a lamp - on constantly,
    since this pretty well never happens.
    Do you find the 'flasher' lamps on your car failing more quickly than
    similar lamps which don't flash?
