Jeremy D. Grotte
I designed and built a circuit to control a bunch of LED's awhile back. It
uses a PIC16F628 to control a few n-channel MOSFETs, and those mosfets in
turn apply a ground to strings of LED's (which naturally have a power
sitting on them waiting to be grounded) which are brightness controlled by
PWM. The circuit works fine until I start loading it down with loads of
LED's, then everything starts to get hot, wiring, MOSFETs, all of it.
Normally this isn't a problem for my project, but in extreme cases (when I
start putting a zillion LED's on it), I'm going to want to design a sort of
'power distribution box'. The idea being that the MOSFETs control another
larger MOSFET, or something, somewhere else. The problem is that my circuit
(which is already built in mass quantity) applies a 'ground to a power', not
a 'power to ground' (if that makes any sense), so I guess you could say I'm
using low-side switching (if that's the correct term?).
I know the answer to this is simple, but I can't seem to wrap my brain
around it at the moment.
The only idea I can come up with is using the outputs I've already got to
switch an opto-isolator, and then use that output to turn on another MOSFET,
which can handle the current load. I know there's got to be a simpler way
to do it, again, I just can't think of what it is, and still keep the
project cheap. Oh, and I can't use a relay because the LED output is a PWM
signal, otherwise this would be a piece of cake... (sigh........)
Thanks for any ideas that come my way...
JDG
The 'D' stands for 'Damned if I can think of it'
JDG
