using I/O pins as chip enable
Discussion in 'General Electronics' started by Pesso, Oct 17, 2005.
  1. Pesso
    Pesso Guest
    I was told that I/O pins could not be used as chip enable for RAM and ROM.
    Is that true? If so why is that?
  2. An I/O pin cannot be used as a memory chip enable if the memory's address
    and data lines are connected to the processor's address and data busses.
    Doing so would certainly violate the processor's bus timing requirements.
    Consider, for example, a reading the memory. The processor fetches the
    instruction that sets the chip enable from memory, then releases the busses,
    and executes the instruction. The memory, now enabled, drives the data bus
    with the data at whatever location happens to be on the data bus at the time.
    The processor now wants to fetch the next instruction and this will contend
    with the memory.
    If the memory's address and data lines are driven by other hardware, though,
    it may very well be appropriate to drive its chip enable with an I/O pin.
    But I'm not coming up with an circumstances in which this might be useful!
  3. Noel Henson
    Noel Henson Guest
    There are memory and peripheral ICs that still have more than one chip
    select inputs. On those, it is possible to use an IO pin as a bank (or IC)
    selector. But that's the only instance I can quickly recall that would be
    different than what you said. Unless of course, you add additional logic to
    the existing chip selects.
    Noel
  4. Jasen Betts
    Jasen Betts Guest
    ["Followup-To:" header set to sci.electronics.]
    not strictly true.
    usually chip enable is connected to the address decoder, if you only want
    to have one chip at a time active on the bus you can use an I/O for that
    purpose.
    Bye.
    Jasen
