using an electromagnet to OPEN a small door
Discussion in 'Electrical Engineering' started by Sammy Taylor, Dec 1, 2005.
  1. Sammy Taylor
    Sammy Taylor Guest
    I'm building a small safe with an electronic strike. When a timer activates,
    the strike releases. I want the door to pop open, and using a spring is
    awkward. I thought a simple electromagnet might work, (activated just AFTER
    the strike releases to prevent pre-load problems.) Can somebody suggest a
    geometry.
    Cheap strong electromagnets seem to be of the U-shaped variety. Can I use
    one
    of these and a permanent magnet to repel each other? (I can't use two
    permanent magnets because the pre-load on the strike can be enough to
    prevent it from opening.)
    Thanks for any help.
    sammy
  2. cbm5
    cbm5 Guest
    Something wrong with just a normal solenoid?
  3. Most security equipment suppliers will sell this type of equipment (access
    control), at least they do in the UK. Suggest you Google and try and find a
    local supplier.
    Rob
