using a UV led as a detector
Discussion in 'General Electronics' started by Peter Lynch, Sep 1, 2007.
  1. Peter Lynch
    Peter Lynch Guest
    The plan is to build some sort of meter for measuring the UV light
    from the sun. Now I'm not talking about UV-indexes or any sort of
    medical/lab-quality measurements, just a hobby level goofing around
    project.
    I know that a normal LED can be used "backwards" as a detector, so
    one option I'm considering is to use an ultraviolet LED, with emmissions
    around 395 nm as the detector. I realise it will probably detect
    normal light too, but hopefuly with a bit of experimentation using LEDs
    of different colours I can take this into account.
    Has anyone got any experience of this kind of thing and in particular
    will a uv LED actually detect at long-uv wavelengths?
    Pete
  2. I am not certain about that - myself, I would try using UV-sensitive
    photodiode (they do make them).
    I would also suggest getting two of the devices, hooking to the opposite
    ends of a differential amplifier and blocking one with glass (which filters
    UV).
    best
    Vladimir Dergachev
