Joerg
Hi All,
Micro controllers can be used to drive a switcher from their PWM output.
Most of us know how to do that. But my question: Is there some nifty
literature on the web or elsewhere about all the trade-offs this entails?
What I mean are trade-offs with respect to PWM granularity, for example.
Suppose the counter runs off 5MHz. In order to arrive at reasonable cost
for the magnetics the PWM output needs to be, say, 300KHz or higher.
That leaves only 4 bits of granularity. So it would idle like a Harley
with worn spark plugs, something that may be ok. Then there is the
feedback. Most uCs with an on-board ADC are out of price range so slope
may have to do. On top of that there may be a limit of one slope
conversion unless eternal muxing is done.
Current mode is another topic. Tough to do on a uC but then again if one
can measure both current and voltage the uC "knows" where about the PWM
should be. But it's all not very precise. Then there is the issue of
making the code that runs the PWM safe and fast enough. After all, one
minor hangup in this area could result in a plume of smoke. Next, there
is the trend to ever lower VCC levels which renders the task of turning
on a FET hard enough non-trivial.
Regards, Joerg
Regards, Joerg
