Using a microcontroller to turn a servo
Discussion in 'Microcontrollers, Programming and IoT' started by lvanghele, Aug 3, 2013.
  1. lvanghele
    lvanghele
    11
    Jul 17, 2012
    Hi, I am looking to use a Servo motor to turn a potentiometer, based on input from a 0-10v analog signal. My question is, how do you use a microcontroller to convert that 0-10v input into a degree of turning from the servo? Any help would be appreciated!
  2. (*steve*)
    25,496
    2,837
    Servos typically require a pulse train with varying mark/space ratio to position them.
    See here.
    You simply use a microcontroller to convert the voltage (0-10V) to a be a string of between 1ms and 2ms pulses.
    Practically, the input siganl will need to be divided by two to bring it into the range of 0 to 5V that most microcontrolers can handle.
    Using an analog read function, you'll get a number between 0 and probably 1024.
    Using a bit of basic math you convert that to a number between 1000 and 2000 and use this to generate pulses of that number of milliseconds.
    However, you might like to consider using one of the digital pot IC's which can do something similar without the need for mechanical stuff (although you'll likely still need the microcontroller)
