Using a microcontroller input as crude comparator (thresholdvariation effects)
Discussion in 'Electronic Design' started by Klaus Kragelund, Sep 3, 2012.
  1. Hi
    I am working on a current mode controlled SMPS. I have a sawtooth voltage ramp (measured current in a sense resistor) and I would like use a digital input pin of a micrcontroller to turn off the PWM that controls the ramp. The ramp moves from 0 to 100mV in 10us.
    I do not have a free comparator on the micro, so I thought of using the digital input threshold as the fast level detect, and an outer loop measuring the current for slow current control. The ramp is offset shifted to just below the threshold since I have a low voltage swing
    But, does the typical digital input have a threshold that moves due to external factors fast, appart from supply voltage? (I only need the positive threshold)
    Klaus
  2. Tim Williams
    Tim Williams Guest
    Doubtful. Most uCs have hysteresis on the input pins, and many don't
    guarantee the magnitude of it. In most applications, input pin hysteresis
    is on the order of 200mV, which would screw up your plan pretty quickly
    (unless you want to amplify it, or use a CT).
    You're effectively depending on the input pin's linear range, which may be
    just as slow as anything else available, in other words not as fast as you
    had hoped.
    Is this a peak current mode control, most likely boost/flyback? If you
    can get access to the full current waveform (the triangle, not the
    sawtooth), average mode control is better -- it's not chaotic.
    Tim
    Deep Friar: a very philosophical monk.
    Website: http://webpages.charter.net/dawill/tmoranwms
    Hi
    positive threshold)
    Klaus
  3. I am only using the positive level, so the hysteresis does not come into play (its reset, since the input goes to zero at the end of the ramp)
    Yes, peak current mode
    Good point, just easier for the circuit implementation to shut off at each period by defined current level
    Klaus
  4. Could do that, was just playing around to see if I could save a package from the design
    Regards
    Klaus
  5. Yes, that's another option. I just wondered about the cheapish solution with the microcontroller input :)
    Klaus
