Using a Karnaugh map I need to
Discussion in 'Electronic Basics' started by DarkPath, Oct 23, 2005.
  1. DarkPath
    DarkPath Guest
    I wants to convert my old hot tub controller, wich is currently using
    relays, to more reliable TTL gates (solid state) and opto-isolators.
    Design and build a logic circuit thatl will replace the control function
    of the relay controller. The all solid-state circuitry would have to
    operate the following functions:
    Switch Input #1-Main Power
    Switch Input #2-Underwater Light
    Switch Input #3-Circulator Pump
    Switch Input #4-Jet Pump
    Switch Input #5-Heat Demand Signal (thermostat)
    Nothing may operate until switch #1 is activated (main power).
    The light swithch (#2)may then be switched on or off independently after
    the main power switch is on. However, they may not operate at the same
    time. If one has been previously turned on, the other will not operate.
    The first motor function to occure will have priority.
    If switch #5 (heat demand) is activated, water must be moving through
    the system, therefore if the water is stagnant, the circulator must
    start automatically. If the circulator or jet pump is already running
    when the heat demand is activated, no other function needs to take place.
    Please reply via usenet. My header is a spam trap
  2. That last paragraph appears to be nonsense. Do you perhaps mean to
    reference inputs #3 and #4? At any rate, as your title implies, a
    Karnaugh map, drawn properly, should do the trick. What was the
    question again? Surely you did not intend for someone on the group to
    draw the map for you? Here's a reference on how to draw a map:
    http://www.ee.surrey.ac.uk/Projects/Labview/minimisation/karnaugh.html
  3. A. Gum
    A. Gum Guest
    Do your own homework
  4. Tim Wescott
    Tim Wescott Guest
    Well, that's a worthy goal, indeed.
    How cleverly you make this sound like a homework problem.
    Why? That sounds like a dumb feature, but a good one to add complexity
    to a homework problem. I'd want the underwater lights to be completely
    independent of the heat/circulation control, and possibly even the main
    power.
    Once again a dumb-sounding feature. Wouldn't it be nicer to have the
    jet pump be on user demand, and the circulator only go on if the
    heater's running but not the jet pump?
    * You don't need to use a Karnaugh map to do this unless you want
    to -- unless it's a homework problem. Simply reverse engineering
    the relay logic, or using solid-state relays may be better.
    * What's the make and model of your hot-tub controller?
    * Here's what you do:
    * Figure out how many internal states you have.
    * List all your inputs and "starting" internal states in
    columns on the left of your page
    * List all your outputs and "ending" internal states in
    columns on the right of your page
    * Since you're dealing with an asynchronous system, append
    two columns for each state with the necessary 'S' and 'R'
    signals for your favorite S-R flip-flops.
    * Enumerate all possible inputs and internal states. Use gray
    code, it'll make generating the maps easier.
    * For each output, 'S' and 'R' signal make a Karnaugh map.
    If you don't know how just refer to your textbook or do
    a web search.
  5. Bret Ludwig
    Bret Ludwig Guest
    I think it was Don Lancaster, before he abandoned electronic design for
    surplus baronage, who decided K-mapping was a waste of time because
    gates were cheap.
    Don apparently didn't profit much from this idea, but some one did.
    Ironically, his name was.....Gates!
  6. Jim Thompson
    Jim Thompson Guest
    [snip]
    IIRC, Don was an APPLICATIONS engineer at Motorola, NOT a DESIGNER ;-)
    ...Jim Thompson
  7. Jim Thompson wrote...
    Whoa, Jim, it's not only IC designers who may be electronic design
    engineers! I'm an electronic design engineer who doesn't design ICs.
    Furthermore, many applications engineers are fully-educated skillful
    electronic designers, for example Bob Pease and Jim Williams, just
    to mention two familiar ones. It's fair to say Don Lancaster is an
    electronic designer, even though he doesn't design ICs. What he did
    at Motorola, I can't say, but many a clueless customer calls up and
    expects (and often gets, if they're big enough) free design work,
    designs that incorporate ICs, rather than design them from scratch.
    This is an issue Jim Williams describes in his app notes, telling of
    an anxious boss who wants to see the customer's design finished.
    It's also a good exercise for IC houses, because it's a good way to
    learn of new IC requirements (e.g., an efficient piezo-transformer
    driver for laptop screen lighting), that may bring in the big bucks.
  8. Jim Thompson
    Jim Thompson Guest
    Back in the '60's Analog chip designs were done around an application
    requirement. Then the applications (aka publications) group wrote it
    up all "purty" and nice... 'cept they often made mistakes. Some of
    the PLL notes are truly hilarious.
    ...Jim Thompson
  9. Jim Thompson
    Jim Thompson Guest
    It got so bad that we designers were spending so much time proofing
    data sheets that we went back to doing them ourselves.
    ...Jim Thompson
  10. John Larkin
    John Larkin Guest
    I've never used a K-map. They always seemed silly to me; I like logic
    that has intermediate terms that mean something.
    Besides, you can do most logic by inspection.
    And besides, FPGA compilers reduce the logic for you.
    Take the current example: the correct solution to the problem isn't a
    K-map, it a statement that the proposed logic is stupid.
    John
  11. keith
    keith Guest
    Ah, so his motive was to *sell* gates, rather than *use* them. I never
    met anyone (outside a sales, perhaps) who believed that more packages were
    better.
  12. Mac
    Mac Guest
    This is readily achieved by using main power to power the other logic
    circuitry. Must be a homework problem.
    What is the antecedent to "they?" It is not clear to me at all. Did the
    professor post the assignment on-line? If so, it would be nice to include
    a URL to the assignment.
    Is this supposed to be a state machine or do you just want combinatorial
    logic? You might ask your professor if the problem doesn't state anything
    about it.
    --Mac
  13. Jim Thompson
    Jim Thompson Guest
    Not everyone has an FPGA compiler laying around. I can still do
    K-maps by hand, but I usually use...
    KarnaughMap Version 4.4.5 by Russell Sasamori, which can handle up to
    5 variables.
    BTW, gates aren't cheap, they consume _significant_ power at high
    speeds, and some of us fret over that ;-)
    ...Jim Thompson
  14. John Larkin
    John Larkin Guest
    Most of the logic we do these days is inside FPGAs, and most of that,
    by cell count, is data paths. And the logic is LUT-based, so pure
    K-map reduction isn't necessarily optimum. Logic in 22V10-type chips
    has its own constraints, like sum-of-products, so that's not classicly
    K-mappable either. And we usually tune for speed, not minimum number
    of gates.
    Professors like K-maps because they're rigid, easy to teach and easy
    to test on.
    The sum-of-products thing is a nice way to clearly document what's
    really going on. One-hot state machines are nice, too. Neither is a
    "classic" technique, where minimizing gates was the goal.
    John
  15. Jim Thompson
    Jim Thompson Guest
    In my situation I'm building my own gates and flops from transistors.
    But usually trivial stuff ancillary to analog functions.
    ...Jim Thompson
  16. Curious, why do you like one-hots? I agree that they're generally
    preferable with FPGA state machines but explicitly coding them
    seems to go against the grain. I always use enumerated types for
    state variables and either let the software decide on the encoding
    or override it (if software chooses poorly) with an attribute.
  17. John Larkin
    John Larkin Guest
    I like them because they're easy to understand, friendly to comment,
    usually are bug-free, and keep fanout down, which helps speed. It's
    easy to duplicate state flops off-to-the-side (two-hot design?) to
    reduce fanout with no speed penalty. I should note that I do most
    logic design as schematics and pretty much expect the FPGA software to
    plop down a flipflop where I tell it to.
    I don't mind trusting a compiler to reduce combinatorial logic for me,
    but I still design the logic with the FPGA cell architecture in the
    back of my head, so I pretty much know what's going to happen and how
    deep the logic will have to be.
    John
  18. Again. one-hots are generally better in FPGAs, but "binary" or
    "gray" encodings are sometimes better. Since I use VHDL for
    control logic (I would prefer to use schematics for data-flow, but
    haven't mixed them) the encoding isn't really all that important to
    *me*. VHDL pretty well documents the state transitions.
    State transition logic is no more than combinatorial logic. ;-)
    Sure, I do the same, though in VHDL. Since synthesizers use
    templates, I know pretty much what logic is going to come out of
    what VHDL coding style. Of course there are FPGA-specific features
    (e.g. fast-carry chains) that may not drop out of behavioral style
    code and structural coding is needed for maximum speed. This sort
    of thing also limits portability, which is important to some.
  19. CWatters
    CWatters Guest
    If the power switch #1 is off do you have another source of power to run the
    logic?
  20. Fred Bloggs
    Fred Bloggs Guest
    DarkPath wrote:
    [snip garbage]
    Try this logic:
    ENGINEERING= HARD_WORK AND APTITUDE
    DARKPATH= NOT HARD_WORKER AND NOT APTITUDE
    ACTION=DARKPATH_GO_DO_SOMETHING_ELSE
