Using a coded door lock to trigger light on a timer
Candace
Dec 28, 2014
Dec 28, 2014
I'm an artist, and I have built a sculpture that uses a coded door lock to trigger a mechanism within a sculpture. I would like to modify the sculpture so that the door lock will trigger a light to come on and stay lit for 60 seconds. I would like suggestions for the easiest way to do this.
Thanks in advance
Bluejets
Oct 5, 2014
6,920
Oct 5, 2014
6,920
Assuming the door lock output is low voltage, Use the pulse from the door lock to trigger a 555 timer.
You may have to invert the pulse though. 555 requires a negative going pulse pin 2.
