jtaylor said:
I need to make three-phase power at 400Hz to run a pair of selsyn fuel-tank
units. It lookes like the simplest approach would be to program a pic and
run some audio power transistors from the outputs. I'd appreciate any
advice.
If you are proficient in code writing, the PIC is a good solution whether
you need single phase or three phase. I wouldn't use a linear amplifier
though, I'd have the PIC drive FET switches directly in a PWM mode. Overall
that would use the least number of parts and be much more stable in both
frequency and amplitude than any analog oscillator-amplifier scheme.
Furthermore, it would not dissipate much power and would be applicable for
any power level from several watts to many kilowatts depending of the FETs
and their drive. It would be very good for low power, battery operation as
well if that is a requirement. On the other hand, if you don't know anything
about code writing in assembly or C, etc. Then your in for some headaches
and a simple oscillator-amplifier might be a better choice.
