Using 15A 250V power cord instead of 10A 250V
Discussion in 'General Electronics Discussion' started by Janum001, Jun 15, 2020.
  1. Janum001
    Janum001
    Jun 15, 2020
    I recently purchased a Led Grow light. The light came with a power cord with a Type B plug. The cable says 10A 250V on it. I live in South Africa and we use a Type M plug. I have another cable form a monitor that says 15A 250V on it, it can also fit into the light.
    Info about the Grow light:
    Power Factor: >97%
    Worldwide Voltage: 85V-265V
    Working Frequency: 50~60Hz
    Now my question is, can I use the 15A 250V power cable instead of the 10A 250V?
    Or must I just go buy an adaptor?
  2. bertus
    bertus Moderator
    689
    240
    Nov 8, 2019
    Hello,
    You can always use a higher amperage for the cable.
    When the amperage would be lower, there might be a problem.
    Bertus
  3. Janum001
    Janum001
    Jun 15, 2020
    Hi
    Thanks for your response.
  4. Nanren888
    Nanren888
    247
    50
    Nov 8, 2015
    Just to add to what Bertus said, it is right that you also checked the voltage rating is the same or higher.
    You can use one that is the same or higher on both voltage and amperage.
    bertus likes this.
