James Sweet
I've got a number of digital clocks around the house that use a 9V battery
to keep time during a power failure. Seems that the batteries only last one
or two power outages and then they're dead which ends up being most of the
time. I found a simple modification to fix this, simply get a 9V NiCd
rechargeable battery, they're actually 7.2v but that doesn't matter. Now
open the clock and follow the wires from the battery snap until you get to
the diode in series with it, this is usually easy to find. Solder a 2.2k
resistor across the diode and measure the voltage at the battery snap,
should be floating somewhere between 10-15V, install the rechargeable
battery and you're good to go. The resistor passes enough current to keep
the battery charged but the diode still allows the full current to pass the
other way during a power outage, no more dead batteries. Depending on the
voltage of the power supply anything from 1.2k to 3.3k or so can be used
just fine, a higher value will result in longer charge time but less risk of
overcharge, too high and it won't fully charge at all. 2.2k has worked in
every clock I've tried so far.
