used Heat Press? and Printed Circuit Boards
Discussion in 'Electronic Design' started by samIam, Jan 31, 2006.
  1. samIam
    samIam Guest
    I did a 6x9 board last night and it came out 85% done ...
    I used the blue toner transfer paper and I am certain I can get 99%
    if not 100% transfer if I could get even pressure applied all
    across the board.
    So I am thinking I should invest in a Heat Press ... you know the
    same device used to transfer logos to white shirts?
    Prices on ebay are too high for something I dont expect to use more
    than once or twice a month.
    I could try and find those stores that do the logo on shirt transfers
    (for company picnics, sports teams, events) but I dont know names or
    where to look?
    Anyone?
  2. Poke around on the net- some people have modified cheap commercial
    laminators to do the trick. The main problem with them is that they
    are not intended to take anything as thick as a typical PCB.
    Best regards,
    Spehro Pefhany
  3. Rich Webb
    Rich Webb Guest
    Here's one spot with info on that:
    <http://www.pulsar.gs/PCB/a_Pages/4_Products/5e_Toner_Applicator/Toner_Applicator.html>
    The "standard" plastic pouch laminators are apparently okay for 0.031"
    stock but do need to be modified for the more typical 0.062" boards.
  4. Have it done and have them send it to you; I use
    http://www.pcbpool.de/ppus/info.html . (The German page have titties on it
    Good ;-)
    Once you start accounting for all the fuss and trouble with chemicals and
    whatnot the price is reasonable.
