than
marginal.
Well, I was thinking I could get more use out of a heat-pump than if it were
just A/C. Couldn't use it *all* year round, but a large percentage.
Of course, my electric is almost 6 times my NG rate ('News' figure, I
haven't verified it), so the heat-pump COP would have to at least run close
to this. But on the other hand, IMHO, NG won't stay this cheap much longer,
and if NG prices rise then the heat-pump idea is even more interesting.
As I understand it, heat-pumps come with a heating/cooling thermostat
already. House warms above ~78, cool the house, if it goes below ~67, warm
the house. The only extra control would be once the *real* heating season
starts, set the NG furnace thermostat and shut off the heat-pump till spring
and the crocus start blooming through the snow.
anyway?
Well..... yes and no ;-)
If I'm going to make the capital outlay for A/C *anyway*, then it just seems
like the heat-pump idea is better IF it isn't too much more money. But I
haven't been able to find any price comparisons between an A/C unit and a
comparable BTU/hr heat-pump. I know it must be more expensive, but are we
talking 10%, 50% or (shudder) 90%??? It's that difference between the two
that could make/break this whole idea. At 10%, I can probably get enough
high-COP operation in the spring and fall to cover investment (especially if
NG prices rise). But at higher numbers, would need to 'sharpen the ole
pencil' and pin it down more precisely.
I've got a few years of NG usage and daily heating-degree-day information,
so with a heat-pump's COP vs. outdoor temperature, I *should* be able to
figure the 'ideal' operating range for each. (once I know the added cost
involved) I want to factor in the extra capital cost of heat-pump to find
true ROI.
The extra running would mean more service/maintenance, but if NG prices
rise, it could end up saving me money in the long run to use A/C, heat-pump
and NG instead of just NG. And more comfortable too ;-)
But then again, there are a lot of folks around here with plain central A/C
and plain NG furnaces. So either nobody thought of it, or the HVAC folks
around here already thought of it and found a good reason why it doesn't
make sense and I'm just missing it. In other words, I'm either ahead of
them, or behind them
