P
Peter Hucker
You remembered this one.
Er.... you tell me not to insult, then insult me in the same sentence?
I have no religion, yes.
No I don't.
I wrote this part, it needs two >, upgrade your software.
No, but the waste won't be as much as the heat movced, unless it's a really crap AC.
My refridgerator uses **** all power.
They have everything todo with it. Go look up some stats on pollution per head from different countries.
I didn't imply that at all.
I have no idea what diameter cable we have. That's up to the electric board. It's up to them to weigh up the cost of thicker cable versus more heating. Maybe it defrosts the water pipes in winter?
It has everything to do with your power consumption, which is what we are discussing.
I'm not a geek, I can't be bothered.
http://www.petersparrots.com http://www.insanevideoclips.com http://www.petersphotos.com
..---..___..
,/', (o\ "\_|
.:| `_ `- ,/| /
/:.`\_,' _..-'
|:.. `-._.-'
|:.. ; | `-.__/'
__...\:::.. ;-.
..---:::::::..`\:::.. |_/
`---"" `\,____ _)
Remove the the then. [Grammatical appallingness may be deliberate, it may not.]
No I don't.
I know the basics of what they do. Heating the house has to
generate that heat. An AC just MOVES the heat.
And generates waste heat in the process. What, do you think you can
compress a gas until it turns into a liquid for free?
Any electricity used is due to inefficiency (like with a lightbulb).
No, the waste heat generated is due to the inefficiency of the
_process_. You really ought to stick with something you know
something about if you don't want to end up with egg on your face.
Oh, but wait... what would that be??? So far, all you seem to be
good at is creating confusion.
You're implying that because we have 200A services our (say)
refrigerators run less efficienly that yours do because you only
have 80 amp services? It's just the other way around moron.
Since your 80 amp services have smaller diameter cable in them than
our 200 amp services do, their higher resistance causes higher
losses due to increased power dissipation and heating of the cable.
Do the math.
..---..___..
,/', (o\ "\_|
.:| `_ `- ,/| /
/:.`\_,' _..-'
|:.. `-._.-'
|:.. ; | `-.__/'
__...\:::.. ;-.
`---"" `\,____ _)
