Use for old circuit boards
Discussion in 'General Electronics Discussion' started by EK61, Dec 2, 2016.
  1. EK61
    EK61
    49
    4
    Jan 5, 2014
    I've got a lot of old boards from electronics, and aside from scavenging components for projects, is there anything I could do with the circuits as they are?
    Could be a stupid question, as although I'm fine soldering and building from schematics, I don't really know much about designing circuits or devices, or how they work.
    These old boards are from things including:
    CRT TV (no tube)
    High end CD player (only the board for the controls is broken)
    Karaoke machine (CD and tape)
    Clock radios
    LCD monitor (was dead, likely caps)
    Dell touchscreen laptop (dead motherboard, touchscreen probably only item of use)
    Many other smaller devices
    I was planning on trying to reassemble the tape player from the karaoke machine, but I couldn't piece it back together (I think some parts were missing)
  2. davenn
    davenn Moderator
    13,812
    1,945
    the PCB circuit tracks will be too specific to do anything much else with
    component recovery is the best thing :)
    done lots of that in the 40+ years I have been playing at electronics
  3. EK61
    EK61
    49
    4
    Jan 5, 2014
    Thought so. Would you recommend mass desoldering everything that looks useful (caps, resistors, etc.) or just leave the boards in buckets to search through?
  4. davenn
    davenn Moderator
    13,812
    1,945
    these days with SMD components, it's better to leave them on the boards ... much easier to search and see component values
    I just use plastic bins and separate boards into their types .... audio, RF, digital etc
  5. Bluejets
    Bluejets
    4,764
    999
    Oct 5, 2014
    We used to run a wood chisel through everything and use the bare board for control horns on model aircraft. Takes superglue like it was made for it.
  6. davenn
    davenn Moderator
    13,812
    1,945
  7. Bluejets
    Bluejets
    4,764
    999
    Oct 5, 2014
    Like this............
    davenn likes this.
  8. 73's de Edd
    73's de Edd
    3,085
    1,302
    Aug 21, 2015
    control horns
    YEAH . . . . .some of which can get on up into the 122 db ear piercing noise thresholds . . . .are used to ward off nearby aircraft .
    Or you might also see a control horn . . . . such as are used on scale models.
    Initially, I guess that he just wanted to strip all of the components from the board proper . . . to get an unpopulated fiberglass or phenolic blank to build from.
    Then some drilling sanding and filing to create one of what you see as the WHITE unit ( control horn) that is being at the receiving end of the servo-control linkage as is being seen for rudder control on this model aircraft.
    It converts the linear direction of the control rod to a rotary action to pivot the rudder . . . . .or aileron . . . . .or elevator . . . . . . or nose wheel steering . . .or throttle control of the engine . . . .or whatever else you need to be done.
    [​IMG]
    73s de Edd
  9. FMC Digital
    FMC Digital
    7
    Dec 1, 2016
    Old/Broken PCBs are not worth anything in my opinion. Salvaging components are probably the only best thing you can do with it.
    Some PCB contains gold, might be worth it to check if yours has any, you might be able to send it to a company that accepts em.
    Cheers,
    FMC
  10. Alec_t
    Alec_t
    2,950
    803
    Jul 7, 2015
    Offer them to your local school/college for coversion to 'works of art'.
    davenn likes this.
