A
Alex Coleman
At home I use an "intelligent battery charger" which charges cells
two at a time and both must be present for the charger to work.
THE PROBLEM .....
Sometimes I want to charge just one cell on its own.
Maybe that one cell is an AA or AAA from a single-cell MP3 player.
Or maybe I have to recharge cells which have very different
capacities or charge levels.
To charge only one cell, can I put a resistor in the place of the
second cell as a sort of dummy cell? If so then what values might I
use?
I figure the Negative Delta V sensor would still trip correctly with
one cell as it's unlikely that two cells would reach their voltage
drop simultaneously.
Tech details are below. Thank you for any info.
Alex
--------------------- TECHNICAL DETAILS -------------------
INFO ABOUT CHARGER ...
The charger is a Vanson V-1000 charger which uses Negative Delta V.
The spec says AA cells are charged at 350mA and AA cells at 750mA.
I read 1.45 volts across one 900mAh AAA whilst charging 2 of them.
I read 1.35 volts across one 2000mAh AA whilst charging 2 of them.
Manufacturers info: http://www.vanson.com.hk/details/p3001.html
Wholesaler's info: http://preview.tinyurl.com/22jdld
INFO ABOUT CELLS ....
Use mainly NiMH with some NiCd
AAA cell capacity ranges from 300mAh to 900mAh.
AA cell capacity ranges from 1000mAh to 2800mAh.
-------------------- END OF TECH DETAILS -------------------
THE PROBLEM .....
use?
Alex
