USB with 5 wires?
Discussion in 'Troubleshooting and Repair' started by Floyo, May 28, 2016.
  1. Floyo
    Floyo
    May 28, 2016
    Hi!
    My USB wire of my keyboard has 5 wires:
    color: connected to on the circuitboard:
    black DRAIN
    red V
    yellow G
    white D
    green C
    I'm guessing that red is +5 volts, black is 0 volts, green is Data + and white is Data - but what is yellow for?
    I saw on the internet that most usb's have 4 wires: red, black, white and green.
    Hoping to find an answer.
    Floris
  2. Heliman
    Heliman
    65
    13
    Feb 4, 2016
    A 5 wire USB is On-The-Go standard (OTG) used alot on keyboards. The yellow wire is used for ID. Here is a picture of the pinout.
  3. Floyo
    Floyo
    May 28, 2016
    If I wanted to connect a longer usb cable, where would the ID wire be connected to, if the usb cable has 4 wires?
  4. KeithM
    KeithM
    41
    4
    Nov 3, 2015
    Is this a standard USB keyboard, or one with some kind of USB Micro plug? If it's a normal one I don't think the yellow wire is actually connected on the other end, or it's pulled to ground.
