USB TV Tuner
H
Harry
Recently bought USB TV Tuner: Compro Videomate U620F
Finding that only ABC and SBS is picked up with included antenna. This is
not so bad since the other channels are mostly rubbish, but I have a few
questions:
1. Do the ABC and SBS broadcast stronger signals because they are government
channels and they are required to provide a service?
2. What influence does the length of the rabbit ears of indoor TV antennas
have on reception?
3. What influence does electricity-powered signal amplification have on
reception?
4. Do external house antennas rely on electricity?
5. What would be the best way to improve reception using an indoor antenna?
Antenna size/length? Electricity powered signal amplification?
A
atec77
is not so bad since the other channels are mostly rubbish, but I have a
few questions:
trolling removed
add rabbit ears OR an external antenna and enjoy
X-No-Archive: Yes
F
felix_unger
trolling removed
what trolling? obviously just wanted info
X-No-Archive: Yes
rgds,
Pete
“If Julia is the answer, then what was the stupid question?!”
"Julia finally got something right. Older people don't vote Labor, because they have seen too many incompetent, mismanaging, money-wasting Labor governments"
"If the WORLD as a whole cut ALL emissions tomorrow, the average temperature of the planet's not going to drop for several hundred years, perhaps over on thousand years" - Tim Flannery, Climate Commissioner
“Wayne Swan threatening the Banks, is a bit like being savaged by a dead sheep!”
Give Juliar the boot!.. http://ausnet.info/pics/boot.jpg
H
Harry
atec77 said:
trolling removed
Already tried cheap rabbit ears but not much joy. Hence my questions which
you snipped and criticised.
S
SG1
questions:
government channels and they are required to provide a service?
Possibly
have on reception?
The bigger the better.
reception?
Can't comment on that one.
Only those with signal amplifiers.
antenna? Antenna size/length? Electricity powered signal amplification?
Hook up to an external antenna, the house should have one.
C
Clocky
have a few questions:
antennas have on reception?
on reception?
amplification?
In strong signal areas you might get away with rabbit ears but even in
medium areas you will likely need a basic external antenna pointed in the
right direction.
Boosters can be helpful but you need a signal to amplify, so if the
reception is really poor it won't help.
S
Sylvia Else
few questions:
Broadcasts are from different places. The obvious idea of coordinating
broadcasting so that transmissions serving an area all come from the
same place is apparently beyond the abilities of Australian regulators.
So the strength of the signal depends, amongst other things, on where
you are relative to each transmitter.
As an energy source, you mean? Not unless they have a mast amplifier.
Sylvia.
H
Harry
Is height the biggest factor?
Intended use will not involve external antenna so not an option.
F
felix_unger
a few questions:
no. maybe you are closer to their transmitters, or their frequencies are
being received better
the longer the better
on reception?
normally it only amplifies what is being received, unless it's a more
sophisticated kind that filters the noise and boosts the signal
no, but you can use a powered mast head amplifier that requires DC
voltage up the antenna cable
put it up as high as possible, and you could use something like this..
http://www.jaycar.com.au/productView.asp?ID=LT3133&keywords=indoor+antenna&form=KEYWORD
generally the best solution is to use an external antenna, even a small
one just mounted on the gutter, or in the ceiling unless you have an
iron roof, is better than an internal antenna where the signal has to go
thru walls, etc.
http://www.radioparts.com.au/ProdVi...0&ProdDesc=COMBO20+COMBINATION+20DB+AMPLIFIED
rgds,
Pete
H
Harry
broadcasting so that transmissions serving an area all come from the same
place is apparently beyond the abilities of Australian regulators. So the
strength of the signal depends, amongst other things, on where you are
I ask the question generally. Would an external house antenna be connected
to electricity, on average?
What is the reason they are better than indoor antennas? Height,
electricity, or some other factor?
A
atec77
which you snipped and criticised.
The answer is deserved , google the answer or take the advice which is
valid
X-No-Archive: Yes
P
Phil Allison
"Harry"
connected to electricity, on average?
** Only rarely in a domestic situation.
Antennas on tops of buildings and blocks of units are another story.
** Having an unobstructed line through the air to the transmitter sites is
the big one - results in a much stronger and much cleaner signal. Plus you
can put up a physically large and efficient antenna that would be absurd
indoors.
It is a near miracle that indoor TV antennas work at all - everything is
against them.
.... Phil
H
Harry
Phil Allison said:
"Harry"
you can put up a physically large and efficient antenna that would be
absurd indoors.
against them.
I remember years and years of using indoor antennas. Is digital TV the
reason why they are no longer viable?
P
Phil Allison
"Harry the Fuckwit TROLL "
"Phil Allison" >>
** Truth is, they were never any good with analogue TV.
With DTV the need for a clean, strong signal is more crucial - if annoying
drop outs are to be avoided.
..... Phil
K
Krypsis
Fully extended, they should be tuned to the middle of the TV frequency
spectrum.
Height is always a factor but that is mainly to get above line of sight
obstructions such as houses, trees, etc.From no signal on analogue to just acceptable. Digital is more picky.
Apartment buildings where signals are split between multiple apartments
usually use amplification. Houses only need it if the signal is low to
begin with.
Get a powered antenna that has the highest gain.
Amplified antenna will be your only option. I think the digital TV
signals occupy a slightly higher spot in the spectrum so a standard UHF
antenna will work but may degrade at one end. Get one suitable for
digital transmission and you should be ok.
We use a signal booster on the TV in the bedroom - too many walls, too
many trees, too far from the outside antennaa. Used to work on analogue
quite ok but some channels snowy. No good whatsoever on digital. May
need to install a splitter and run a cable from the outside antenna to
solve my issue.
In your case, I suggest you either borrow a amplified antenna and try it
or get a guarantee from the shop that you can return with no penalty if
it isn't up to scratch.
P
Phil Allison
"Krypsis"
spectrum.
** Err no.
Fully extended they tune to channel 2, half extended is channel 7.
Amplified antenna will be your only option. I think the digital TV signals
occupy a slightly higher spot in the spectrum so a standard UHF antenna
** You seem to be unaware that DTV is mainly on VHF channels in all capitol
cities.
The VHF channels used are 6, 8, 9A, 11 & 12 plus a couple of UHF channels
for SBS etc.
DTV antennas for capitol city use are quite compact and cover all the above.
..... Phil
K
Krypsis
Generally no.
External antennae a usually placed in a high position clear of line of
sight obstructions. As well, they have a much higher gain factor and you
can see this by the number of elements on them. The rabbit ears are a
basic dipole antenna and will have two active elements only. A
directional external antena will have the two active elements plus a
variable number of director and reflector elements. Director elements
are progressively shorter whilst reflector elements are progressively
longer than the active elements. Directional antennae, like those on the
rooves of houses everywhere, provide much more signal gain.
http://tinyurl.com/2xetan
http://tinyurl.com/2bro57k
A couple of websites to help you gain a better understanding of antennae
types.
K
Krypsis
I suspect it is. Even a poor analogue signal will provide a snowy
picture can still be viewed. A poor digital signal will just freeze or
drop the picture out completely.
