Usb solar charger
Discussion in 'General Electronics Discussion' started by coreydebruin, Oct 24, 2012.
  1. coreydebruin
    coreydebruin
    Oct 24, 2012
    hi,
    ok so, I'm currently trying to create a Solar charger for my Huawei U8180i Phone
    I would be using a 5W (12v) solar panel, the battery is 3.7v 1200mAh (4.4W),
    now I was thinking of sticking the solar panel to the case and making a usb port somehow and attaching the solar panel to it then just using the phone's usb charger with that...
    my concern however is I may overload the circuit due to the voltage difference, so I need someone to tell me if that's actually safe or if I need to change the voltage or change something else, and if so how I should go about it.
    thanks,
    Corey
  2. (*steve*)
    25,505
    2,852
    Get hold of one of the many USB adapters for cigarette lighter sockets.
    These efficiently convert a voltage near 12V to 5V and have the required USB connection.
    If you look in the right place you'll find them for a couple of bucks each including freight.
