USB Power
Discussion in 'General Electronics Discussion' started by Delphawi, Sep 4, 2012.
  1. Delphawi
    Delphawi
    3
    Sep 4, 2012
    Hello
    I need to connect some (or all) of three components I have to a Laptop USB port to use it as a power for the circuit . The power specifications for them are the following:
    First one DC12V , 0.18A
    Second one DC05V , 0.17A
    Third one DC12V , 0.14A
    How can I use the USB power to make my circuit work ? how many components I can run using a single USB cable ?
    Thanks in advance
  2. BobK
    7,682
    1,686
    That is a total power of 4.7W. A USB 2.0 port can supply only 2.5W and a USB 3.0 port can supply only 4.5W. So you are out of luck even at 100% efficiency for converting the 5V power to 12V.
  3. Delphawi
    Delphawi
    3
    Sep 4, 2012
    Thank you
    But how can I convert the 5V to 12V ?
  4. BobK
    7,682
    1,686
    You would use a DC-DC converter. But as I already explained, you cannot draw enough power from a USB port to power the devices you want.
  5. Delphawi
    Delphawi
    3
    Sep 4, 2012
    I guess I would use 1 or 2 of them only ..
    Thank you .
