USB on micro SD slot problem
Discussion in 'General Electronics Discussion' started by excrucio, Apr 11, 2010.
  1. excrucio
    excrucio
    6
    Apr 11, 2010
    How to connect usb stick on micro sd slot??
    (transced JF V30 16GB stick)
    Anyone to help???
  2. 55pilot
    55pilot
    434
    3
    Feb 23, 2010
    You can not connect a USB memory stick to any kind of a SD slot. They are two totally different interfaces.
    ---55p
  3. excrucio
    excrucio
    6
    Apr 11, 2010
    that's not right,
    you CAN connect usb to micro SD, the device is called mobidapter, I think, but it's expensive to me so I'm trying to make my own
  4. 55pilot
    55pilot
    434
    3
    Feb 23, 2010
    You can connect everything to a PC and transfer the information. Instead of using a PC, you can use one of many micros to emulate a SD card and then have the micro be a master to a USB device. That is what the device you are talking about most probably does. It is not easy or simple, hence the cost.
    Bottom line, you just can not "connect" a USB device to a SD slot.
    ---55p
  5. excrucio
    excrucio
    6
    Apr 11, 2010
    you didn't get it
    just google mobidapter and you'll see
  6. 55pilot
    55pilot
    434
    3
    Feb 23, 2010
    I looked at their website and it does exactly as I had speculated. The white body has a microprocessor that emulates a SD card to the phone/PDA while acting as a master to the USB.
    If you do not want to buy their product, then you need to do a lot of electrical and mechanical engineering to get things in the right form factor and then A LOT of software on the embedded micro to achieve the functionality that they have, exactly as I had suggested earlier.
    No matter how badly you want it to be so, it is not as simple as just connecting a few wires from one connector to another.
    ---55p
  7. excrucio
    excrucio
    6
    Apr 11, 2010
    ok
    you are right
    i was hoping that is simple
    but i was wrong
    it is looks like that i must buy mobidapter
