EventHorizon
- Nov 14, 2011
- 1
- Joined
- Nov 14, 2011
- Messages
- 1
Hello all! I'm working on an introductory level engineering project which revolves around geothermal energy production. Essentially our design is going to take pressurized steam and pass it through a "turbine" to generate electricity. I have salvaged 2 fans connected to a usb cable from an old laptop cooling fans to use as the turbine system. I know that in the same way power can be applied to a motor to make it run, a motor forced to run physically will produce some current. My question is whether this current can be detected by using a multimeter on some pins in the USB connector which the fans are already attached to. I know that pin #1 in the plug is the VCC +5 V pin, however how can I use this to detect a current, if at all? Would it make more sense to just remove the plug entirely and detect current via the wiring instead? Any help would be greatly appreciated!
