USB converter B type female to A type female
Discussion in 'General Electronics Discussion' started by vick5821, Aug 10, 2012.
  1. vick5821
    vick5821
    700
    Jan 22, 2012
  2. Harald Kapp
    11,662
    2,697
    Does the UC00B work without the adapter (pluging it directly into the computer's USB port)?
    Why do you need an USB A / USB B adapter at all?
  3. vick5821
    vick5821
    700
    Jan 22, 2012
    Yes, the UC00B work fine. Problem occurs at my DIY circuit. I need that because the UC00B is so short and very inconvenient. I need an extension so that I can use it better :)
  4. (*steve*)
    25,497
    2,839
    Assuming you have the power connection correct, my next guess is that you have the data+ and data- connections swapped over.
  5. Harald Kapp
    11,662
    2,697
    Just use an USB type A extension cord.
    Avoid the hassle with a PCB.
  6. vick5821
    vick5821
    700
    Jan 22, 2012
    Harald, I dont have the A type extension.
    @steve,
    swapped over means I misconnect them ? I dont think so
  7. vick5821
    vick5821
    700
    Jan 22, 2012
    what weird is that, I just solder the USB B type female to a stripboard. Then I plug in the USB B male, then it gave me that error message. LOL
  8. (*steve*)
    25,497
    2,839
    I thought I made a mistake once, but I was wrong.
  9. vick5821
    vick5821
    700
    Jan 22, 2012
    What do you mean by that ?
  10. Harald Kapp
    11,662
    2,697
    Just give it a try... See what happens.
  11. vick5821
    vick5821
    700
    Jan 22, 2012
    See this. ! So I dont think it involve the misconnect of D+ and D-. Cause I just solder them
  12. Harald Kapp
    11,662
    2,697
    You just solder the connector to a PCB but no electronics?
  13. Harald Kapp
    11,662
    2,697
    Can you show us (or better yet: link to) data sheets for the type A and type B connectors? I mean the ones you use, not just general information.
  14. vick5821
    vick5821
    700
    Jan 22, 2012
  15. Harald Kapp
    11,662
    2,697
    The connections seem to be o.k..
    Try to locate the USB device in the Windows device manager and delete it there. You may have to install a suitable driver for the UCB001 board before connecting it to the PCB.
  16. vick5821
    vick5821
    700
    Jan 22, 2012
    Erm , I am not connecting UC00B. When I plug in the USB B male from printer cable to USB B female from DIY converter, it already gave me the error . I didnt even conenct a device to the USB A type female on the DIY converter. I think does not involve the driver or what
  17. (*steve*)
    25,497
    2,839
    Check to make sure you haven't accidentally shorted one of the data leads to ground, or VCC or even shorted VCC to ground.
  18. Harald Kapp
    11,662
    2,697
    Do you get the error if you only plu in the cable to the PC, nothing on th eother end of the cable (no PCB at all)?
  19. vick5821
    vick5821
    700
    Jan 22, 2012
    No error :D
  20. Harald Kapp
    11,662
    2,697
    Then there is an error on your PCB, possibly a short. Verify with an Ohmmeter that the plug on the PCB has no shorts.
