A
asdf
I hope someone would be able to help I want to add one smal device to my
computer by soldering it to the inside of the USB connector. If I do so,
would I stil be able to use this same connector from the outside, in the
regular way?
I have a small USB dongle (BLuetooth) that I would like to "install" into my
notebook. When used as a dongle, Bluetooth is constant source of the
problems: I must pair it often or I do not have it with me when I need it.
I would therefore solder a small cable to the back of the USB port inside of
my notebook and connect the dongle to that cable and just place such
combination inside, where I have spare place.
Can this be done and stil retain usage of such USB port from the outside or
I could not connect any other devices on the outside while this "inside"
Bluetooth dongle is active or I could never use external part of the
connector?
Regards,
Davor
regular way?
connector?
Regards,
Davor
