USB analog Output control, cheaply?
Discussion in 'Hobby Electronics' started by Lord-Data, Sep 25, 2005.
  1. Lord-Data
    Lord-Data Guest
    Excluding driver side of things for a moment, does anyone know a cheap and
    basic way to make some kind of analog or stepped output control via USB? The
    task is spinning a motor at varying speeds, a pump, in this case.
    Jaycar have a kit, but it also includes 2 analog intputs and 8 digital I/O
    lines, which are of no use to me, and at $65, more than i'd like to spend
    for a project that may scale up later on ..
    Anyone know a kit or system that can do this, simply and basically? I'd
    prefer a pre-developed system, vs using and programming a PIC myself .. i've
    got electrical expeirence, but 0 experience using/programming PICs..
    Thanks in advance!
  2. ....
    The picaxe range of products together with a cheap USB to serial adaptor
    would be a good solution.
    picaxe.com sells the usb to serial adaptor for 6 GBP, and the entry picaxe
    for AU $4.70.
    Total AU cost would then be under $20, and under $5 if you don't mind using
    a serial port instead of USB. Serial strings would be much nicer for you to
    program with. Very simple compared to finding USB drivers etc.
    And don't worry about not having programmed microprocessors before. Picaxe
    is as easy as it gets. It would be much harder (but still easy) to create
    the control software to send out the serial strings to the picaxe than it
    would be to program the picaxe to receive serial strings, and control the
    pump using PWM.
  3. quietguy
    quietguy Guest
