G
galapogos
Hi guys,
I'm developing a USB 2.0 high speed device that is currently very much
functional. However, I'm having some problems with radiated emissions
test with both FCC and CE standards. Based on the sweep from
30-1000MHz, I'm pretty convinced it's a USB 2.0 problem, because I see
distinct spikes at 240, 480, 720, 960MHz, which are probably harmonics
of the 480MHz USB 2.0 sweep. These spikes occur on 2 different PCs
that I use, and they disappear when I use another laptop that only has
a USB 1.1 port.
I'm wondering if anyone has had experience designing USB 2.0 devices
for FCC/CE compliance? I understand that many factors could cause
these spikes, ranging from the power source, actual test PC used,
cable length/shielding/gauge, cable layout, etc...I'm wondering which
ones are the ones that cause the biggest difference. Booking the test
lab is kinda expensive and I have no equipment to perform debugging so
I hope I can do the most I can before hand to solve this problem
before showing up at the lab.
Thanks in advance!
a USB 1.1 port.
Thanks in advance!
