USA wall wart in the UK
Discussion in 'General Electronics Discussion' started by Bamse, Sep 22, 2019.
  1. Bamse
    Bamse
    10
    Nov 9, 2018
    I am getting a device from America that runs off a supplied wall wart. It's no doubt 12v or around that.
    My question is, if I just get a USA 2pin to UK plug adapter, will this be sufficient? I wouldn't a step down converter?
  2. davenn
    davenn Moderator
    13,798
    1,939
    look on the walwart and see if it has a voltage range input pretty much all of them do these days and most of them will work from 110 - 240VAC
    Again, CHECK its label
    Bamse likes this.
  3. Bamse
    Bamse
    10
    Nov 9, 2018
    Great, thank you.
  4. Audioguru
    Audioguru
    3,131
    698
    Sep 24, 2016
    If the wall wart is lightweight and small then it does not have an old fashioned large and heavy low frequency transformer in it and instead it is a modern electronic circuit that uses a lightweight high frequency transformer. The modern ones work from a wide range of supply voltages.
    Bamse likes this.
  5. Bamse
    Bamse
    10
    Nov 9, 2018
    Yeah, I've got a pictures now and it's 110v - 240v so should be fine. Thanks
    davenn likes this.
