EasyTrax
DOS Freeware version 2.06 - Complete PCB layout package with output support for printers, pen plotters and Gerber.
System requirements: PC-compatible; DOS 2.0 or later; 640K RAM; 2Mb of hard disk space.
Download (ZIP 485 KB)
http://techdocs.altium.com/display/ALEG/Easy trax
Notes from readers:
Designspark PCB: Requires a registration which is free but it’s bug-ridden and last time it didn’t work. Support couldn’t solve it. Later I realised it required constant connection to the net with cookies enabled.
Fritzing is a toy.
Kicad I found to be full of bugs to the extent of uselessness. I deleted it when I found myself fighting the software rather than designing a PCB.
FreePCB wasn’t maintained for the last three years – since 2011. This tells the story.
TinyCad is what the name says: tiny. The library is extremely limited. For example there are only 11 microcontrollers.
ExpressPCB is anything but express. Very difficult to use it. If you re-position a part, you have to re-align every-single-connection going to it. This means, every corner of every line. This is perhaps the most cumbersome to use among all of these. Badly limited library.
Some software will freeze-up and you will lose everything you have done. Other software cannot be saved as a file. You cannot send it to any PCB manufacturer. It can only be sent to the expensive manufacturer that supplies the software.
PCB manufacturers:
http://www.elecrow.com/
www.smiery.com
You will need to contact me for all the tricks and short-cuts.
Colin Mitchell
[email protected]
