Urgent - LM1458
Discussion in 'Electronic Design' started by Alan Smithee, Nov 27, 2003.
  1. Alan Smithee
    Alan Smithee Guest
  2. Ben Bradley
    Ben Bradley Guest
    In sci.electronics.design, "Alan Smithee"
    Most any op-amp, whether dual in one package, quad in one package,
    or two singles, will work in this circuit, as long as the max power
    supply voltage ratings is less than the +V and -V values. The 5532
    will work but it's overkill. but you should put a 5k or so resistor in
    series with the wiper of the 25k pot. The 5532 has internal diodes
    across the + and - inputs, and if the pot were turned up to the output
    side with more than half a volt acrosss the output cap, it would dump
    a lot of current into the diode and burn it out. Other op-amps might
    not like their inputs going above their positive supply, either:
    there's no voltage given for +V and -V, and if the out voltage is
    greater than +V and the pot is turned up, the - input could go above
    the +V op-amp supply.
    Hey, aren't you a famous film director?
  3. Alan Smithee
    Alan Smithee Guest
    Thanks very much - situation is now resolved
    Yes, but I'd rather not talk about it
  4. Ben is quite right that essentially any dual opamp will work.
    Myself, if I were building that circuit and had the luxury of choice, I'd
    look for an opamp with low DC offset and low bias current, to improve
    accuracy. But myself, I wouldn't build that circuit in the first place.
    Instead, I'd probably use a variable regulator chip, such as the LM317:
    better reliability, fewer parts. If I wanted the adjustable current
    limiting I'd keep the "bottom" part of the circuit, although I'd probably
    use a comparator instead of an opamp.
    But you say you're in a big hurry, so the answer is "use whatever you've
    got, it don't matter".
