URGENT HELP..
Discussion in 'Microcontrollers, Programming and IoT' started by guratasta, Oct 7, 2013.
  1. guratasta
    guratasta
    7
    Aug 23, 2010
    Hai all...help me please..
    What can I do to replace the common cathode 7 segment in this project, to common anode 7 segment...????? I am having trouble finding 7 segment CC in my place. thanks for all ... I really hope for this assistance.
  2. (*steve*)
    25,490
    2,832
    We've been through this quite a bit before.
    In this case if you replace the BC547's with a PNP equivalent and invert the circuit (the transitors are between the +ve rail and the common anodes) AND then change the code so that all the outputs are inverted, it will work with common anode.
    If you can't change the code it's a real pain. and often fairly difficult (or at least required another 12 transistors and resistors, etc.
