ups apc bk300c
I'd like to disable the sound on my APC BK300C battery backup. I found
the little device on the printed circuit board which is causing the
really annoying and nasty sound. It's a black circular object. Is it
possible to fill in the hole thereby muffling the sound? Or can I
remove the object and re-solder something in it's place?
Here's the little noise maker itself:
http://www.opalfire.net/front.jpg
Here's the top of the printed circuit board ... the circle is where
it's located.
http://www.opalfire.net/top.jpg
Why not just cover the hole with a piece of masking tape?? If that
doesn't muffle the sound enough, cut one of the pwb leads to the
sounder itself.
H. R. (Bob) Hofmann
Yeah I could try the masking tape thing. But I was really hoping to
totally eliminate the sound. How can I cut one of the leads when it's
flush on the circuit board?
K
Kalman Rubinson
Desolder them.
Kal
Using a sharp Exacto type knife, cut one of the traces on the pwb that
go to the sounder. Make two cuts 1/16 inch apart on whichever trace
goes only to the sounder, and then use the edge of the blade to lift
the copper trace between the two cuts. But I would really try the
masking tape first as it should do a pretty good job and isherder to
screw up than cutting a wrong trace.
H. R.(Bob) Hofmann
B
Bob in Phx
all joking aside, I normally crush the thing with vice grips. Solves the
issue right quick. Of course, please be sure to unplug the device and the
batteries!!!
bob in phx..
p.s. this is a permanent fix, where as masking tape is temp!!!!!
jakdedert
H. R.(Bob) Hofmann
Grab the thing with a big pair of pliers and crush it. Snip off any
pieces that are left with a pair of dikes....
jak
jakdedert
batteries!!!
bob in phx..
Great minds....
I hadn't read the above before I posted the exact fix.
jak
Sounds like a plan ... I'll let you know how it goes ... thanks for the
ideas! Since I've not had much experience with circuit boards I wasn't
sure what to do.
Thanks!
All worked fine guys thanks for your help! I now have a noiseless
battery backup!
I just would have assumed removing that sounder would have somehow
caused the device not to work.
