- Joined
- Jun 21, 2012
- Messages
- 4,886
I would try both. Increase the value of the collector resistor so saturation occurs at something less than ten milliamps, say 1.5 mA and at Vce (sat) = 250 mV. Decrease the base resistance to make sure the transistor is driven into saturation, Vbe(sat) > 700 mV. Increase the capacitor values to compensate for the decreased value of base resistor. Try these values and see what happens: Rc = 3.3 kΩ, Rb = 2.7 kΩ, C = 0.89 nF. You could start out with C = 1 nF = 0.001 μF (a common value) to see if it oscillates (a bit on the low frequency side of your target frequency) and then introduce a variable resistance for Rb to raise the frequency to 300 kHz.Therefore you need to decrease the base resistor's values or increase the collector resistor's values.
I am not a great fan of simulation, until I know that a circuit works with real components, and then the simulation can be used to gain some insight on what happens when component values are permutated. Monte Carlo analysis is good for finding out how a circuit behaves over extremes of component values, either temperature induced or simply caused by component value tolerances. LTSpice is one of the better simulator softwares available, but it may need a little "help" to get the circuit oscillating. IMO, the best "simulator" is a pair of transistors, four resistors, and two capacitors wired up properly and connected to a stable voltage supply to implement an astable multivibrator. Once you have that working, adjust component values for the desired effect.
An oscilloscope is an invaluable tool to use when "playing" with oscillators.
I agree completely. Picofarads and solderless breadboards do not mix well for prototype circuits. Also, for frequencies much greater than a few kilohertz, it may be easier to buy or build a crystal oscillator and divide the frequency down with binary counters. RC circuits do not make oscillators with good frequency stability. OTOH, LC oscillators are usually adequate if designed to oscillate at sufficiently high frequencies and then divided down.Maybe it is built on a solderless breadboard and its stray capacitance between all the rows of contacts and wires and inductance of its many long wires prevent the very low value capacitors and very high value base resistors from working properly. ...
