B
Brad
Thanks to everyone who offered their help.
I managed to get the TV to stay on, although I didn't find out what
actually was causing the shut down. I have Photofact 4968 for this model TV,
but there is no information about IC7200, TDA9577H. I couldn't find a data
sheet for this IC on the web. I suspect it relates to the beam current
sensing circuit or IC7200. Parts tested good and voltage measurements
were right on, or not far from values in Photofact.
I noticed if I increased the brightness with the pattern generator, the
TV starts to go off. I reduced (which were not set very high) the picture
settings such as brightness and picture/contrast, as well as the color level.
Then I increased the "screen" a small amount. Note: I had tried different
"screen" settings before, but that didn't fix the problem.
Now the picture is a pretty good (it was good before), and the TV stays on.
I ran it on and off for a number of hours.
Brad
Brad
