Unusual Floating-Point Format Remembered?
Discussion in 'Electronic Design' started by Quadibloc, Mar 31, 2007.
  1. Quadibloc
    Quadibloc Guest
    Currently being voted on by the IEEE, an extension to the IEEE 754
    floating-point standard will include the definition of a decimal
    floating-point format.
    This has some interesting features. Decimal digits are usually
    compressed using the Densely Packed Decimal format developed by Mike
    Cowlishaw at IBM on the basis of the earlier Chen-Ho encoding. The
    three formats offered all have a number of decimal digits precision
    that is 3n+1 for some n, so a five-bit field combines the one odd
    digit with the most significant portion of the exponent (for a range
    of exponents that has 3*2^n values for some integer n) to keep the
    coding efficient. Its most unusual, and potentially controversial,
    feature is the use it makes of unnormalized values.
    One possible objection to a decimal floating-point format, if it were
    used in general for all the purposes for which floating-point is used,
    is that the precision of numbers in such a format can vary by a whole
    decimal digit, which is more than three times as large as a binary
    bit, the amount by which the precision varies in a binary format with
    a radix-2 exponent. (There were binary formats with radix-16
    exponents, on the IBM System/360 and the Telefunken TR 440, and these
    were found objectionable, although the radix-8 exponents of the Atlas
    and the Burroughs B5500 were found tolerable.)
    I devised a scheme, described along with the proposed new formats, on
    http://www.quadibloc.com/comp/cp020302.htm
    by which a special four-bit field would describe both the most
    significant digit of a decimal significand (or coefficient, or
    fraction, or, horrors, mantissa) and a least significant digit which
    would be restricted in the values which it could take.
    MSD 1, appended LSD can be 0, 2, 4, 6, or 8.
    MSD 2 or 3, appended LSD can be 0 or 5.
    MSD 4 to 9, appended LSD is always 0.
    In this way, the distance between representable values increases in
    steps of factors of 2 or 2.5 instead of factors of 10, making decimal
    floating-point as "nice" as binary floating-point.
    As another bonus, when you compare the precision of the field to its
    length in bits, you discover that I have managed to achieve the same
    benefit for decimal floating point as was obtained for binary floating-
    point by hiding the first bit of a normalized significand!
    Well, I went on from there.
    If one can, by this contrivance, make the exponent move in steps of
    1/3rd of a digit instead of whole digits, why not try to make the
    exponent move in steps of about 1/3 of a bit, or 1/10 of a digit?
    And so, on the next page,
    http://www.quadibloc.com/comp/cp020303.htm
    I note that if instead of appending one digit restricted to being
    either even or a multiple of five, I append values in a *six-digit*
    field, I can let the distance between representable points increase by
    gentle factors of 1.25 or 1.28.
    But such a format is rather complicated. I go on to discuss using an
    even smaller factor with sexagesimal floating point... in a format
    more suited to an announcement *tomorrow*.
    But I also mention how this scheme could be _simplified_ to a minimum.
    Let's consider normalized binary floating points.
    The first two bits of the significand (or mantissa) might be 10 or 11.
    In the former case, let's append a fraction to the end of the
    significand that might be 0, 1/3 or 2/3... except, so that we can stay
    in binary, we'll go with either 5/16 or 11/16.
    In the latter case, the choice is 0 or 1/2.
    Then, the coding scheme effectively makes the precision of the number
    move in small jumps, as if the exponent were in units of *half* a bit
    instead of whole bits.
    But now a nagging feeling haunts me.
    This sounds vaguely familiar - as if, instead of *inventing* this
    scheme, bizarre though it may sound to many, I just *remembered* it,
    say from the pages of an old issue of Electronics or Electronics
    Design magazine.
    Does anyone here remember what I'm thinking of?
    John Savard
  2. Not at all sure why you keep writing this, John -- that's the way
    amost all existing decimal floating-point arithmetic works, and has
    done for several hundred years. It was, perhaps, controversial around
    1202 in Europe (e.g., Liber Abaci, by Fibonacci) -- but since 1500 or
    so, that's the way arithmetic has been done, even in the late-adopting
    countries of Europe. :)
    mfc
  3. Quadibloc
    Quadibloc Guest
    LOL!
    People designing floating-point units for computers, however, have
    somewhat different tastes from those using pencil and paper. As a
    result, while they never even considered using Roman numerals for that
    purpose, other aspects of how decimal arithmetic is done by hand have
    tended, as a general practice, to be modified in the floating-point
    units of computers.
    John Savard
  4. |>
    As I pointed out, this is at most a storm in a teacup. The reason that
    those formats were found objectionable was the truncation, and had
    nothing to do with the base. There is no critical reason not to use
    a base of 10 as against a base of 2. And I speak as someone with
    practical experience of writing and porting base-independent numerical
    code.
    My arguments with Mike have nothing to do with saying that decimal
    is harmful IN ITSELF. They are that the way IEEE 754R decimal is
    being spun is misleading and often incorrect, and the consequences
    of this are harmful, verging on the catastrophic.
    Regards,
    Nick Maclaren.
  5. My arguments with Mike have nothing to do with saying that decimal
    As far as I know, 'IEEE 754r decimal' is not being "spun", at all -- in fact
    people opposed to it seem to be far more noisy about it than those who are
    quietly using it.
  6. Quadibloc
    Quadibloc Guest
    In most cases, the truncation is a _consequence_ of the base.
    I *have* come up with a way in which one could have a base-10 format
    whose truncation is (almost) as gentle as that of a binary floating-
    point format, though, so I know that an exception is possible.
    I do not know if any controversy has, in fact, raged around the
    proposed DFP format, but I suspect that if there are people who find
    the format off-putting, most of them will be exercised not by subtle
    differences in numerical properties, but instead, when they notice the
    free use of unnormalized values - and then see the "ideal exponent"
    rules - they will realize that this isn't their grandfather's floating-
    point, and that something rather novel is being done here.
    Some, seeing this bold and novel idea, will stand up and applaud.
    Using the z9 implementation as an example, they will not feel
    threatened by it - if the new format runs much slower than binary
    floating-point, clearly, it isn't intended as a replacement, and so if
    it has poorer numeric properties for classic floating-point
    applications, that isn't really an issue. It's there to take computers
    into new applications.
    But others will see this as just the beginning - and, certainly, if
    the transistors are worth it, hardware implementations of DFP having
    near-parity in speed with binary floating-point are possible. If DFP
    can do everything BFP can do, and then some, why not? And if that is
    an eventual possibility, DFP ought to be put under intense scrutiny
    right now, before it's too late!
    Well, if there _is_ controversy, my humble contribution might just
    save DFP. Because what I worked out is a DFP that looks "just like"
    binary floating point. The storage efficiency is the same as BFP - I
    managed to simulate hiding the first bit! The truncation changes by
    small steps nearly as small as those of BFP - good enough to answer
    your specific example, for which the threshold is radix-4.
    The same hardware could handle both my trivial modification of the DFP
    proposal *and* the one proposed as the standard. So there would simply
    be a choice between format-centric DFP and numeric-centric DFP, and it
    would be safe to drop binary floating point, because numeric-centric
    DFP would preserve those of its good points perhaps not fully
    reflected in the current DFP proposal.
    John Savard
  7. |> > My arguments with Mike have nothing to do with saying that decimal
    |> quietly using it.
    I have tried to give you credit for being honest and fair, but it is
    getting increasingly hard. Your Web pages spin and postings spin the
    advantages of decimal, and so do a hell of a lot of things taken from
    them - the Python Decimal class documentation, for example.
    All I have ever done is to point out the misleading claims, both ones
    of fact and ones of presentation, and the inconsistencies; and to point
    out that, in the opinion of all the people with extensive numerical and
    pedagogical experience that I know of, the value judgements used to
    justify decimal are mistaken.
    To point out one egregious inconsistency, you have claimed that the
    use of 128-bit decimal for fixed-point calculations will be universal,
    that the cost of implementing decimal is only a little more than that
    of binary and that decimal is intended to replace binary. I can't
    recall whether you (or others) have also said that decimal is NOT
    intended to replace binary, but be in addition, in order to say that
    my points are irrelevant - but it has been said by its proponents!
    Those CANNOT all be true at once.
    1) The cost of implementing decimal is slightly more than the
    cost of implementing binary only in the case of the VERY heavyweight
    floating-point units produced by IBM. I don't know its cost in the
    other ones, but would expect it to be at least twice as much in the
    stripped-down ones favoured for embedded work. And that is not just
    development and sales cost, but power consumption for a given
    performance.
    2) Where floating-point is a major factor, the use of 128-bit
    arithmetic doubles the cost for a given performance (or conversely),
    as the current bottleneck is memory access. Twice as much memory
    with twice the bandwidth costs twice as much and needs twice the
    power. You simply can't get round that.
    3) If you don't use 128-bit arithmetic, there WILL be overflow
    problems with fixed-point. You can't enable trapping, because the
    exception that needs to be trapped MUST be ignored when you are using
    the arithmetic for floating-point. I won't go into the errors made
    by the IEEE 754(R) people about why language support is effectively
    absent, but that isn't going to change.
    Regards,
    Nick Maclaren.
  8. |>
    Correction. Except for Professor Kahan.
    I will repeat, ad tedium, that the universal opinion is that there is
    essentially no difference between binary and decimal floating-point
    for numerical work. The former is marginally better for 'serious'
    work, on many grounds, and the latter marginally more convenient for
    'trivial' work.
    Regards,
    Nick Maclaren.
  9. I have tried to give you credit for being honest and fair, but it is
    I think you must be using the word 'spin' in a different way than I do :).
    I point out facts, but that's not 'spin'. And I don't think I refer to the
    'advantages' of decimal arithmetic anywhere...
    I actually expected the 64-bit format to be the more popular. It was a
    surprise to me that people are standardizing on the 128-bit format. On the
    costs, the components needed are about 15%-20% more than binary, according
    to most references. That is actually quite significant when multiplied
    over a large number of cores.
    I have never said that decimal is intended to replace binary. If your data
    are in binary, why convert to decimal?
    I cannot imagine how it could be twice; a decimal adder, for example, is
    only slightly more costly than a binary one (it has to carry at 9 rather
    than 15). Multipliers are more complex, to be sure (but lots of people are
    doing new research on that). On the other hand, zeros and subnormal numbers
    are somewhat easier to handle in the 754r decimal formats because they are
    unnormalized and so zeros and subnormals are not a special case. And, of
    course, an all-decimal computer wouldn't need a binary integer unit :).
    Of course. The same is true of 128-bit ('quad') binary arithmetic, too. I
    rather assume most binary FP processing will migrate to that size, too, just
    as it migrated from single to double when the latter became widely
    available.
    We are somewhat agreed on that :). However, one can detect possible
    rounding even at the smaller sizes (with the effective loss of a digit of
    precision) by checking the MSD (which is conveniently in the top byte of the
    encoding). If it is still zero after a multiplication, for example, there
    was no rounding (except possibly for subnormal results, but when doing
    fixed-point arithmetic one is unliklely to be anywhere near the extremes of
    exponent range).
    mfc
  10. |> > I have tried to give you credit for being honest and fair, but it is
    You do, frequently, which is is reasonable. What you don't do is give
    fair weight to the disadvantages and, more importantly, phrase your
    claims in ways in which the naive will assume that the advantages are
    more than they are.
    http://groups.google.com/group/comp.arch.arithmetic/browse_thread/
    thread/1c9d39e3aa57952d/fb34632082279900?lnk=st&q=&rnum=2&hl=en#fb34632082279900
    Mike Cowlishaw wrote:
    Yes, there was a smiley. But I remember similar remarks without them,
    perhaps in Email. And IEEE 754R makes decimal an ALTERNATIVE to binary,
    despite the claims that it is supposed to be an addition.
    You can use the same multiplier and divider as integers, and those units
    are MUCH larger than the adder; conversion to and from integers is vastly
    easier, and so on. The IEEE 754R format also forces the support of
    unnormalised numbers, which adds extra complexity even for comparison.
    For reasons that you know perfectly well, there isn't the chance of a
    flea in a furnace of integers becoming decimal during either of our
    working lifetimes, or a couple of decades beyond.
    |> available.
    Well, Kahan and others disagree, on very solid grounds. It may happen,
    but not in the foreseeable future.
    |> exponent range).
    If programming in assembler, yes, you can. You can ALMOST do that when
    using a high-level language as a pseudo-assembler, but I know of nobody
    skilled enough to achieve it for most important languages. It can be
    done for Java, for example, but not Fortran or the C-derived languages.
    Regards,
    Nick Maclaren.
  11. Quadibloc
    Quadibloc Guest
    Were it not for the support of unnormalized numbers, the "ideal
    exponent" rules would not be possible, and without those rules,
    indeed, there would be "no difference" between decimal and binary, and
    less reason to add decimal.
    In the event that chips start using real estate for really fast
    implementations of decimal floating-point, I suppose that a new
    architecture *might* be designed that tries to save transistors by
    dropping binary, on the theory that decimal can do anything binary can
    do, but more understandably to mere mortals. Since, as you've noted,
    that isn't _quite_ true in a few cases, I'm happy that I've shown how
    decimal can be made more like binary - should this day ever dawn.
    It may also be noted that the use of DPD (as opposed to packed BCD)
    for the decimal format *already* makes the comparison of decimal
    floating-point numbers rather complex.
    John Savard
  12. OTOH, universal HW support for the 128-bit decimal fp would make it the
    default choice for all those algorithms where you suspect binary 64-bit
    (double) might not be good enough.
    Personally, I would _much_ rather have 128-bit binary fp, but when faced
    with the choice between sw-emulated 128-bit binary and hw-implemented
    decimal, I would at the very least like to run my possibly marginal
    64-bit algorithms a few times in decimal and compare the results. :)
    Terje
  13. Why can't you do so in any language that allows operator overloading,
    i.e. C++?
    Replace the stock operations with your own that checks all results?
    Or is the problem that you cannot do it while maintaining useful
    performance?
    Terje
  14. Not really:
    Any hw-supported DFP implementation will have to have a parallel chunk
    of gates that converts between 10-bit DPD and 12-bit BCD format.
    Even if your adders and multipliers could accept DPD directly, you would
    still need the pack/unpack unit to handle scaling by a 1 or 2 (mod 3)
    digits.
    The DPD_to_BCD conversion is effectively a 9-bit lookup table with
    11-bit results (the parity bit is passthrough), so each instance of this
    table requires 512*11=5632 bits.
    Going the other way you need an 11-bit index into a table returning
    9-bit results, so that is 2048*9=18432 bits.
    Having 4 such tables and pipelining the accesses would handle conversion
    in a very small number of cycles, but it might be faster to create
    explicit logic to handle the conversions and save on lookup table space.
    The obvious way to implement DFP would be to convert between DPD and BCD
    during all load/store operations, and expand the internal registers to
    work directly in BCD.
    I.e. I'm not particularly worried about the conversion overheads.
    Terje
  15. Jerry Avins
    Jerry Avins Guest
    Terje Mathisen wrote:
    Do any of you involved in this discussion imagine that it has relevance
    to embedded, low-power systems? If not, please don't cross post to
    comp.dsp any more. I think we get the idea here, and it's interesting in
    general, but not in the details.
    Jerry
  16. |>
    |> i.e. C++?
    Because the problem is not with the operations - it is with the overall
    model, especially the memory and state ordering aspects. In C-derived
    languages, that is so ambiguous that nobody knows what the standard
    specifies; at least in Fortran, it is just plain unspecified.
    To take a simple (!) example, setting an exception flag (which are
    essential to any IEEE 754 model) is a side-effect, and therefore
    should not occur twice between sequence points (which ordering is
    itself inscrutable beyond the understanding of mere mortals). The
    attempt to specify an exemption for them foundered before it got
    anywhere.
    |> performance?
    That is the second problem, and is why Java is such a dead duck where
    performance matters.
    Regards,
    Nick Maclaren.
  17. |>
    Regrettably, it does - and I have spent quite a lot of the past decade
    trying to argue the embedded, low-power corner to various people. I am
    handicapped in that by knowing only a little bit more about that area
    than the people I was talking to :-(
    The point here is that the commoditisation of CPUs is increasingly
    leading to 'standard' ISAs being used in the embedded market, and an
    increasing amount of software that runs on such things is developed
    at least initially on 'general purpose' CPUs. That is why it is such
    a pity that the embedded, low-power people have not been more active
    in the languages and related standards activities.
    Think to yourself. If you were told to redesign your software or
    firmware for a system with 128-bit decimal as the only hardware
    floating-point, while still maintaining performance and power, how
    would you do it? And it isn't implausible that you will be faced
    with that in a decade's time.
    Regards,
    Nick Maclaren.
  18. It may also be noted that the use of DPD (as opposed to packed BCD)
    In software, on Pentium M x86, the lookup (a 2-byte x 1024 table) is so fast
    (LEA) that I have not been able to reliably measure any difference between
    code using the lookup and code not using it (i.e., < 1%). In hardware it's
    3 FO4 gate delays (or 2, if the inputs have complementary ouputs, as
    ususally the case for CMOS). Whether the latter bumps one into a new cycle
    or not depends on the design (some processors have a 13 FO4 cycle, so 3 of
    those is significant; others have a much wider cycle).
    'Me too'
    mfc
  19. I read comp.dsp fairly often, and hadn't thought of it as a place
    for embedded low-power systems.
    I do believe that floating point is overused in DSP problems,
    where wider fixed point would probably be a better choice,
    but that is a different question.
    As many people do use floating point for DSP, even if I
    don't agree, though should probably be interested in some of
    the problems with its use.
    -- glen
  20. Embedded folk have stronger imperatives than that. Either it doesn't
    matter, because the embedded system in question is in a radar system or
    some such and can drink as much power as it likes (in which case the
    off-the-shelf chip will probably do the trick), or it matters so much that
    there's no way that it will get a look-in: the guy who does (whatever) in
    less silicon, with fewer watts/longer battery life will walk away with the
    business. Mostly that means fixed point, rather than even binary floating
    point. The other big "embedded" (i.e., non-user-programmed) user of
    floating point is gaming graphics, and I suspect that that's a field safe
    from the scurge of decimal arithmetic for the forseeable future, too.
    (Most of that stuff doesn't even bother with the full binary IEEE FP spec,
    of course: just what it takes to get the job done.)
    Also: if on-chip parallel processing ever gets useful, then there may well
    be significant pressure to spend the gates/area/power on more binary FUs
    than fewer decimal FUs. Outside of vector co-processors and GPUs, I have
    my doubts about that.
    So: python and C# (both popular languages) are going to add 128-bit
    decimal float to their spec, and Java already has it? This works fine on
    binary computers, I expect. I also don't expect that there will be *any*
    applications that would get a significant performance boost from a
    hardware implementation, so customer pull will (IMO) be minimal.
    The only reason that this is being thought of at all is that no-one can
    think of anything better to do with the available transistor budget...
