Unstable power supply voltage output.
Discussion in 'Electronic Repair' started by Factor21, Jan 24, 2007.
  1. Factor21
    Factor21 Guest
    Hi!
    I have a Princeton VL1812 LCD Monitor which won't start due to a
    failing power supply.
    I've measured the +12V output of the power supply and it fluctuates
    violently between 11 and 13 volts without a load attached. The +5V line
    is stable (w/o a load).
    When connected to the monitor, both the +5V and the +12V lines drop
    significantly below their values (more than 70%).
    I connected a regular ATX power supply to the monitor and it started
    just fine.
    I can't seem to find this power supply anywhere online in order to buy
    it.
    Can you please suggest a way to find a similar/compatible power supply.
    Can you use FCC's site (or some other site) to search for compatible
    parts? If so, how does one exactly do it?
    Do you have an idea of what the max current ratings for the +12V and
    the +5V would be?
    Any suggestions will be greatly appreciated.
    Thanks!
  2. hapticzee
    hapticzee Guest
    get a reasonable off the shelf 12/5 v supply used in external scsi drives
    and such. they usually have output abt 4 amps capacity. cannibalizing can
    usually find something even cheaper. most run from 110ac too.
    just do some creative wire splicing.
    much cheaper than exact propietary replacement expense.
  3. Jamie
    Jamie Guest
    almost sounds like bad caps to me?
