Unspecified capacitor
Discussion in 'Datasheets, Manuals and Component Identification' started by nebojsa, Jul 22, 2017.
  1. nebojsa
    nebojsa
    40
    May 13, 2017
    I need info for this capacitor, at least voltage value.
    [mod note - image resized]
  2. Minder
    Minder
    2,912
    610
    Apr 24, 2015
    Looks like an OEM part No,
    What is the application?
    AC motor start cap?
    If so what is the voltage of the motor.
    M.
  3. kellys_eye
    kellys_eye
    4,281
    1,146
    Jun 25, 2010
    Looks like a capacitor from a flash gun.....
  4. Arouse1973
    Arouse1973 Adam
    5,164
    1,078
    Dec 18, 2013
    Yes correct, Metz make flash guns, some of the capacitors were made by Rubycon. Not sure on the value but the I would have thought the voltage rating is going to be 300 Volts plus.
    Adam
  5. nebojsa
    nebojsa
    40
    May 13, 2017
    It is capacitor from old metz flash.
    44 AF.
  6. nebojsa
    nebojsa
    40
    May 13, 2017
    Yes, its over 300v, but i need more precise value. I found in some shematic 360 or 385v. But, could it be higher?
  7. Arouse1973
    Arouse1973 Adam
    5,164
    1,078
    Dec 18, 2013
    I don't know is the honest answer I haven't looked at all the flash guns out there.
    Adam
  8. kellys_eye
    kellys_eye
    4,281
    1,146
    Jun 25, 2010
    Voltage rating should equal or exceed the stated value to be suitable to install.
    If you get one of around 330μF and 450V it will likely just 'drop in' and work. Modern capacitors tend to be smaller than earlier versions although rated just as highly so fitting an 'identical' replacement isn't necessary and the modern equivalent will likely fit the space available.
  9. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Is this from a Metz 44 AF-4 ?
    The 331 code is probably 330WV .
    The capacitance value isn't written on it ,it is probably coded.
    What does the schematics say?
    You can also inquire directly with Metz Here.
Similar Threads
Loading...
