T
TKM
| |>I understand that linear tungsten halogen bulbs emit noticeably more
|> UV light than general household incandescent bulbs.
|> Would it be safe to use a 300 Watt tunsten halogen floodlight as a
|> good bright light in my home office?
|> This would be on for approx 8 hours a day. I'm wondering that maybe
|> after that sort of exposure the extra UV could become a significant
|> adverse effect on eyes & skin.
| To answer your question -- yes, tungsten halogen lamps do emit
substantial
| amounts of UV and they are perfectly capable of causing skin and eye
damage
| if you are directly exposed to the light of an unshielded lamp. In
Italy
| some years ago, users of small halogen task lamps reported sunburn and
other
| UV-related problems because the lamps were not shielded.
| But a piece of glass will filter the UV to minimum levels and the
halogen
| lamps should be enclosed anyway in case of bulb rupture. You definitely
| don't want to experience that in a home office situation.
| As others have said, however, there are much better, more efficient and
| safer ways to light your office using fluorescent lamps.
I'm looking for a way that results in a uniform continuous spectrum. I
have
found that fluorescent does not accomplish that. Also, LED does not,
either.
But I think there may be hope in that LEDs are available is lots of
different
wavelengths. A mix of a lot of these could come close to the continuous
spectrum.
| Phil Howard KA9WGN | http://linuxhomepage.com/
http://ham.org/ |
| (first name) at ipal.net | http://phil.ipal.org/
http://ka9wgn.ham.org/ |
NIST has a current project to build an LED lighting system that has sources
which emit at every 5 nm (I think). Each "color" would be individually
controllable in output. What I didn't understand when I heard about it is
how they expect to find or tune LEDs to the various wavelength bands.
Terry McGowan
