A
anon
I wonder if anyone can point me in the right direction.
I'm a hobbyist building a timing system for use in amateur bicycle
races in the UK. Commercially available systems use RFID tags and cost
many thousands of pounds. We don't need something that gives
world-record levels of accuracy so I decided to design a cheaper
system.
The way it works is this: each competitor carries a small circuit with
a microcontroller and passive receiver. On each lap, they pass over an
induction loop. This triggers the microcontroller, that has a crystal
controlled oscillator. It saves the lap time, and at the end of the
race they are all uploaded to a computer. It's a lot simpler than an
RFID system that would need to read multiple tags simultaneously. And
at the end of the race everyone has to return their expensive tags or
else they don't get their times.
I've managed to get prototypes working at both 8khz and 125khz (RFID
frequency).
My understanding is that frequencies below 9khz are unregulated in the
UK, though presumably there may be other restrictions on emitting
magnetic / electromagnetic radiation below these frequencies (EMC
considerations?)
I would prefer to use 125khz as this would be less likely to interfere
with hearing aids, pacemakers or heart-rate monitors. The power I need
is far less than the power that an active RFID tag requires. So I feel
my system would be unlikely to interfere with anything that a legal
RFID transmitter would not interfere with. But I can't find anything
that confirms this frequency is unregulated and believe me I've looked
hard. My tags aren't technically RFID tags as they only receive, and
don't transmit.
So which frequencies might be legal for me to use? And are there any
other restrictions on power output?
Thanks.
system.
frequency).
considerations?)
don't transmit.
Thanks.
