Unknown Part
Discussion in 'General Electronics Discussion' started by Alex123, Mar 13, 2016.
Thread Status:
Not open for further replies.
  1. Alex123
    Alex123
    5
    Mar 13, 2016
    I've been disassembling a circuit to see how it works and have come across a part
    that no-one in my uni is 100% sure about
    [​IMG]
    Would be great if someone can identify it for me
  2. davenn
    davenn Moderator
    13,883
    1,966
    either a printed resistor or inductor
    what did it come out of?
    where in the device did it come from
    make model and more photos
  3. Alex123
    Alex123
    5
    Mar 13, 2016
    [​IMG]
    It comes from an ignition circuit/spark generator. Has no model number on that part. But it would most likely be a inductor in that case since it's in the secondary side of the transformer where there will be no reason for a resistor to be there
    Sorry if I'm being very vague. It's hard to explain :S
  4. davenn
    davenn Moderator
    13,883
    1,966
    no probs
    The pic didn't really help unfortunately
    have you used a multimeter in Ohms range and see if you can measure a resistance of the part ?
  5. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    My bet is it's a heating element. ..
  6. Alex123
    Alex123
    5
    Mar 13, 2016
    Just checked and the multi-meter is not able to measure any resistance in the part o_O
  7. davenn
    davenn Moderator
    13,883
    1,966
    OK so it may be open circuit
    any chance of a better pic of it ... it's small and far away in that first pic you posted
    is there any text on it on either side ?
  8. ChosunOne
    ChosunOne
    417
    121
    Jun 20, 2010
    Some transformers have fuses on the secondary side. That would explain the zero-resistance.
  9. davenn
    davenn Moderator
    13,883
    1,966
    this part isn't a transformer tho ;)
  10. Alex123
    Alex123
    5
    Mar 13, 2016
    [​IMG]
    [​IMG]
    [​IMG]
    My camera is struggling to focus. These are the best I can get them close up.
    There is no letters or numbers on it which seems a bit strange o_O
  11. davenn
    davenn Moderator
    13,883
    1,966
    thinking this should be clarified ...
    did the meter real OL or 0.0 or something else ?
    That's ok :)
    still looks like a carbon track resistive element on a ceramic substrate rather than an inductor
    What its purpose is, without seeing a diagram is almost impossible to tell ?
    have you tried to google for a circuit diagram or anything else ?
  12. Alex123
    Alex123
    5
    Mar 13, 2016
    The multi meter showed 0.0 as if it's an open circuit.
    Suppose it was a resistive element. Would it be used to limit the current on the secondary?
    My task is to reverse engineer it for part of my project :eek: from what I can see, the primary side has a self oscillating MOSFET to control the switching. Secondary side has a few capacitors and diodes that look like they are arranged as a voltage multiplier and with that ceramic part connected in parallel to few of the capacitors.
    I'm guessing this circuit follows a few concepts of what I'm looking at
    [​IMG]
    And the product I have is something like this
    http://m.ebay.com/itm/DC-6V-12V-to-...gh-voltage-Generator-/141812580611?nav=SEARCH
  13. davenn
    davenn Moderator
    13,883
    1,966
    Sorry mate
    thread closed
    we do not discuss the building of weapons
    please reread the forums rules that you agreed to when you joined the forum
    cheers
Thread Status:
