Unknown electronic symbol
Discussion in 'General Electronics Discussion' started by carloncho, Sep 3, 2018.
  1. carloncho
    carloncho
    Sep 2, 2018
    Hallo comunity,
    in a circuit diagram of a SMPS there are symbols D1 -D8 (see annex) which I dont know. Can anyone tell me what is the meaning and purpose of them.
    Thanks in advance for any answer.
    Carloncho
  2. davenn
    davenn Moderator
    13,837
    1,952
    I assume you don't really mean D1 - D8 as different types of diodes are referred to
    I suspect you really mean D1,D2,D5,D6,D7,D8,D19 and an unmarked one in the top right … prob. D9
    They are a twin diode pack
    where the cathode of one diode is commoned with the anode of the other diode
    I would have to search for a specific part number
    are you sure it isn't already listed somewhere on the circuit sheet ?
  3. Externet
    Externet
    762
    166
    Aug 24, 2009
    Can be the lower right connected as counterparalleled, A1 to K1.
    [​IMG]
    When 'circled' can mean LEDs :
    davenn and Cannonball like this.
  4. 73's de Edd
    73's de Edd
    3,104
    1,312
    Aug 21, 2015
    Sir carloncho . . . . . .
    Are you just grasping for straws in zeroing in on those parts, as being at fault?
    The schematic shows the 8 sets to be current and voltage sampling for the 4 (or more) CCFL backlight lamps and feeding back correction to the OZ960 CCFL controller .
    Give your specific SAMSUNG model number and more info can be forthcoming.
    With the board connected back into the unit and then plugged in and powered up . . .is 13VDC power present at the R15-R13 junction feeding pins # 3-4 of the OZ and pin 3 of each of the 4539 power driver FET's ?
    PARTS DATA . . . . . BAV99L
    73's de Edd
    Richard9025 likes this.
