Unknown accessory
Discussion in 'General Electronics Discussion' started by philpense, May 14, 2015.
  1. philpense
    philpense
    4
    Apr 17, 2015
    Attached is an image of a cabled accessory with a pin connector. The other end somewhat resembles a microphone. Tested for sound... not a mic. the depression in the head is NOT a hole to allow sound. Looking for an informed opinion
  2. davenn
    davenn Moderator
    13,865
    1,956
    looks like a microphone
    you pic is very blurry and hard to really see
    An informed opinion would require more info from you ;)
    what was it an accessory with ?
    what sort of plug is on the other end ?
    D
  3. Kiwi
    Kiwi
    374
    93
    Jan 28, 2013
    What plug is on the other end?
    How many wires?
    Are they shielded?
    Are they twisted pairs?
    Any chance of a clear photo?
  4. shrtrnd
    shrtrnd
    3,823
    519
    Jan 15, 2010
    Yeah, more information please.
    It looks like your 'pin connector' MIGHT be an 'RCA Plug' commonly used for audio/video.
    I can't really get a good look at the other end of the cable. I'm wondering if maybe it might be a 'load' resistor' somebody made-up for test situations,
    Do you read a resistance across your pin connector of 50 or 75 ohms?
  5. philpense
    philpense
    4
    Apr 17, 2015
    Much thanks for the timely reply. As of this writing, my only camera is a Blackberry curve. Trying to troubleshoot the resolution issue. the pin plug jack is identical to all of my headsets. Connected it to a Windows 7 notebook to test it as if it were a microphone. No sound levels seen when using the 'recorder' app. Blackberry camera settings are: 1600 X 1200, Quality: Superfine, Flash setting: Automatic. Have taken images from varying distances with no change in clarity... Will experiment without the flash and with a separate light source in the hopes that the exposure time will drop and eliminate the blur. Also might tape the blacberry to a tripod. Much thanks for your continued support
