| On 14 Feb 2009 06:41:17 GMT,
[email protected] wrote:
|>| On 12 Feb 2009 02:13:59 GMT,
|>|>|> Source supply is 2 phases taken from a 3 phase system, such as 208Y/120 as
|>|>|> found in USA and Canada, or 220Y/127 as found in Mexico. In Mexico, it is
|>|>|> more common to have 120 degree phasing than to have 180 degree phasing.
|>|>| The "2 opposing phase line" still have a 180 degree relationship to
|>|>| each other, moron. Two lines *CANNOT* be 120 degrees from each
|>|>| other. <sheesh>
|>|>So you really have THAT narrow of an electrical power engineering experience
|>|>level? Sheesh. I guess I will have to dismiss *EVERYTHING* you post as from
|>|>someone who simply does not have much experience in power systems. Maybe you
|>|>don't even have any.
|>| I know enough to know that you're a clueless twat!
|>Whatever you think you know, it isn't enough for anything useful.
| Perhaps form your perspective that's true; you aren't anything
| useful.
What I stated is still correct. Just because YOU can't read it does not
change anything. There are others who understood what I wrote.
|>|>I actually have worked with equipment connected to lines that actually are
|>|>120 degrees apart from each other. Theese were 120 volts relative to ground
|>|>and had a voltage difference of 208 volts between each other. The NEC even
|>|>has specific rules for this kind of system (so there are a LOT of other
|>|>electrical engineers and electricians that have plenty of experience with
|>|>these kinds of systems). For example NEC 310.15(B)(4)(b) which says that
|>|>this kind of system requires including the neutral conductor in conductor
|>|>counts for derating purposes, since it will carry current even when both of
|>|>the 120 degrees-apart current carrying conductors have equal resistive loads
|>|>at PF 1.
|>| I repeat, maybe you'll get it one day, TWO wires CANNOT be 120 degrees
|>| apart with respect to each other. I don't care how many phases were
|>| generated. Ever hear of 208 single phase?
|>So now you change the words to suit your own agenda? Look at my post to see
|>I'm talking about a TWO phase angle single phase system which is actually a
|>THREE WIRE system.
| I didn't change your words, idiot.
Call it a "change", or not, or call it something else. But it is YOU who came
up with the notion of "TWO wires" in this thread. Granted that you did insist
there cannot be a 120 degree phase angle between just two wires. There cannot
be a 180 degree phase angle, either.
Maybe you know stuff. But your personal difficulty (which I have seen before a
few times in this newsgroup) is understanding what you read. Or, maybe you are
just making stuff up intentionally just so you can have an opportunity to make
accusations at people. You and a handful of people on the net are like that.
|>quoted again:
|>The "2 phases taken from a 3 phase system" is a THREE WIRE system. But this
|>is something you apparently don't comprehend.
| Don't lie. You said:
| "But what about the ability to safely operate in all electrical
| systems in the world (at the 200-240 volt configuration in
| countries like USA and Japan that operate on 100-120 volts
| L-N with 2 opposing phase lines which may be 180 degrees
| apart, or may be 120 degrees apart).
| I gave you a chance to correct your insanity which you, like the
| little girl you are, decided to make worse by attacking.
There is nothing to be corrected. It is already correct as it stands. But,
since you have reading comprehension problems, I'll try to explain it for you.
The reference to "2 opposing phase lines" are the specific wires one may
connect to in order to get a certain voltage, which in most homes in the
USA should be a nominal 240 volts. But these are THREE wire systems, or
in some cases THREE of the total of FOUR wires. The neutral is there.
It is part of how the system is derived and how it is measured. Just
because many loads use and work with just 2 of the 3 or 4 wires does not
mean the system does not have 3 or 4 wires.
My postings are NOT (usually) intended to be complete beginner tutorials.
Some assumptions of understanding will be made in order to keep postings as
succinct as possible to get my point across. If it failed for you then I
would be sorry about that if you were a beginner seeking to understand new
stuff, and I would be willing to explain things. But YOU don't seem to fit
that category. You know enough to be dangerous. I can't do anything about
that. it's your problem and you are the only one who can fix it.
I did not start any attack. You (and the "other Phil") did. You've done
this before in past threads, some with me, and some with others. So I'm not
surprised.
|>|>I would suggest you stay away from these kinds of systems. But if you deny
|>|>they even exist, then I'll have to suggest you stay away from all power systems
|>|>since your ability to recognize what you are dealing with is in major doubt.
|>|>You wouldn't know you are dealing with a 120 degree system if you believe it
|>|>cannot exist. And that makes you a danger around electrical power wiring of
|>|>those kinds of systems.
|>| Yes, I deny that two wires can be 120 degrees apart. It is
|>| IMPOSSIBLE, you stupid twit! Draw the bloody phase diagram.
|>It's a very REAL system that exists. It's a very REAL system that the NEC
|>has code written to deal with issues specific to this kind of system. Do you
|>deny the NEC?
| Two wires *CANNOT* be 120 degrees apart, you stupid twit! A plane
| *requires* a third point, idiot. I sure hope you aren't an engineer.
Again, I never said two wires can be ANY degrees apart. That is entirely in
your imagination. I referred to 2 phase angles. That *IS* a minimum of a 3
wire system. I didn't need to explain that in the context of this newsgroup.
If I were writing in alt.engineering.electrical.students.freshmen, then maybe
I would be expected to explain that.
I am a software engineer. I have taken electrical engineering courses as
high as the senior level (in digital design). I never took power engineering
courses. But I did understand many of the basics of electrical power as early
as junior high school. I even worked out the mathematics for polyphase systems
myself even with the limited level of trigonometry I had at the time. I did
learn more about power systems, and in particular, electrical codes, over the
past 25 years, because I was involved in designing data centers where power
loading, cooling, and related issues had to be figured in. I did take courses
in audio engineering and signal processing. I know what phase angles mean.
