Hello all, i have been tinkering with some series universal motors out of a vacuum cleaner and circular saws and would like some insight into the mechanism that determines directionality of the motor. Unlike dc motors i have used in the past, changing the wiring to the armature in relation to the field windings does not cause the motor to run in reverse. Instead, these motors still run in the same direction, which implies the cause of directionality is independent of the wiring configuration. So my question is this: are the windings on the armature on these motors designed so that they will only go in one direction? If not, then what does cause this unidirectionality?
Thank you
Thank you
