Unity Gain
Discussion in 'General Electronics Discussion' started by piedon, Jun 13, 2013.
  1. piedon
    piedon
    Jun 13, 2013
    Hello Folks, just trying to get an understanding of what unity in electronics is and would like your opinion on how I understand it.
    From what I understand, unity come into play with ocillators and amplifiers. If unity is 1, there isn't any increase or decrease of the output signal. If unity is greater than 1, the output will increase in amplitude, if the untiy is less than one, then the output will begin to dampen and decrease.
    Does unity corolate to the impedance between components?
    Thank you for the help.
  2. (*steve*)
    25,497
    2,838
    Unity can mean several things :)
    For example, you may have unity voltage gain (i.e. the voltage out is the same as the voltage in), but your output allows a greater current. This is known as a buffer and can allow a high impedance signal to drive low impedance inputs. It also provides a gain in power.
    The gain doesn't correlate with impedance of components. The input and outpu currents do to a greater extent though.
    Also note that a negative gain has meaning. A gain of -1 is a unity gain, but where the output is inverted with respect to the input. This is a 180 degree phase shift.
    Other phase shifts can also occur but it is complex to describe them. In this case "complex" means you need to use complex numbers.
  3. davenn
    davenn Moderator
    13,836
    1,951
    or you can have unity gain across a range of frequencies
    that takes some electronics effort as usually when left uncontrolled, gain will vary greatly with frequency
