Unit of a capacitor is K?
Discussion in 'Electronic Basics' started by [email protected], Mar 17, 2007.
  1. Guest
    Pal:
    I have a question regarding the unit of capacitors. I thought the
    units are pf, u, or f.
    For example, a capacitor could be 0.01 uf; another could be 470
    pf. But today I saw one that says on its body 560 k. I thought that
    is
    a unit resistors use, for example, a resistor could be 100om or 400K.
    So I am puzzled. Anybody has any enlightening ideas?
    Best wishes to you! Dan
  2. Phil Allison
    Phil Allison Guest
    ** If "K" is marked on a cap after the value, it generally indicates that
    value has a tolerance of +/- 10%
    "J" indicates 5%.
    ........ Phil
  3. Guest
    Phil:
    Thanks for your help! In addition to J abd K, are there any other
    letters used to indicate tolerance, like A through Z?
    Best! Dan
  4. Phil Allison
    Phil Allison Guest
    ** "F" = 1%
    "G" = 2 %.
    "M" = 20%
    ....... Phil
  5. The K isn't a unit, but a tolerance code. See:
    http://my.execpc.com/~endlr/markings.html
  6. Eeyore
    Eeyore Guest
    It's short for 560pF. K is the tolerance (10%).
    Graham
